Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
  1. #21
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2721DE
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 980 Pro
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    111
    1,648
    Indeed, the PCIe 6pin are wired like the Encore 6pin
    A PCIe 6pin cable is therefore good
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 980 Pro
    SOUND: Asus Xonar Phoebus
  2. #22
    ROG Guru: Yellow Belt Array Desertum_0's Avatar
    Mar 2013
    19
    191
    Quite confusing.
    Can I just use any PciE 6 pin cable (GPU cable) so I can connect to this 6 pin power plug?
    I was hoping to just connect the 2x 8 pin plugs and call it for the day.
    Edit: It seems that after all it was a typo from asus and that 6 pin is not a EPS power plug but rather a normal 6 pin GPU plug.
    Please confirm that this is correct.
    Thanks
  3. #23
    ROG Guru: White Belt Array
    Apr 2017
    23
    87
    Quote Originally Posted by Desertum_0 View Post
    Quite confusing.
    Thanks
    Yes, you can use the PciE 6 pin cable (GPU Cable) I used it too
  4. #24
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    111
    1,648
    Same for me, 6pin for GPU
    Case: Lian Li A77F
    CPU: i9 10980XE
  5. #25
    Mar 2013
    19
    191
    Quote Originally Posted by einsindrei View Post
    Excelent new Tistou.
    I see you are using the encore now.
    Do you find it better than the Rampage VI extreme?
    I also want to ask you where is the right M.2 slot to install the intel Optane M.2 ssd?
    Merci.
  6. #26
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    111
    1,648
    Merci.
    Frankly, I did not look for the OC (samen settings with R6E)
    The VRMs heat up slightly less than those of the R6E (watercooled)
    On the other hand the management of the voltageof the rams is catastrophic
    The Samsung M2 is installed on the DIMM.2 and the optane 905P is in PCIe
    Case: Lian Li A77F
    CPU: i9 10980XE
  7. #27
    Mar 2013
    19
    191
    Quote Originally Posted by tistou77 View Post
    It is a beast of a board but is still very buggy, not many BIOS updates from ASUS except yours
    I also wanted to ask you if I could Raid 2x Intel 900p in Raid 0 ?
    Currently I do not have any Intel SSD M.2 but rather 1 Samsung 960 PRO and 1 Samsung 970 Evo pro.
    Thanks my friend.
  8. #28
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    111
    1,648
    I think you can do a RAID0 but I'm not at all "good" in this field
    sorry my friend
    Case: Lian Li A77F
    CPU: i9 10980XE
