11-28-2019 03:21 PM - last edited on 03-06-2024 07:21 PM by ROGBot
12-02-2019 05:31 AM
JohnGalt wrote:
I think at one time I may have stumbled onto what I thought was a setting to turn off USB ports at pc shutdown....I have a 7 port external USB hub plugged into one of the USB 3.0 ports on the mobo and it's full of a bunch of stuff...lighted keyboard, external drive, printer,etc,etc,etc....I'd like for it to power all that stuff off , but it stays on when I shut the pc down. Anyone know where that setting is in the BIOS to disable power to the USB ports at pc shutdown?
Thanks
12-02-2019 02:17 PM
ROGStrixGL12CX wrote:
open command prompt as administrator and type "shutdown /s /f /t 0" without quotes
or press shift while shutting down using Win 10 GUI
Win 10 is using hybrid shutdown as default
12-03-2019 10:34 PM
JohnGalt wrote:
thank you, I'll give that a go
