Results 1 to 4 of 4
    New ROGer Array
    Oct 2019
    2
    Strix GL703 GE Fan Problem (Almost Fixed!)
    I had this model for 2 months now. I had the fan problem shared in this forum many times. The GPU fan always works full speed even when the laptop is idle!
    What I do is using "Furmark ROG Edition x64" just when I start the laptop and use GPU stress test for 2 or 3 minutes. It increases the GPU temperature to reach around 65 degree Celsius. Weirdly, the fan speed drops gradually till it stops and the laptop acts perfectly afterwards.
    I do not have an explanation but thought to share my experience as it may helps others.
    Thanks
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    46
    492
    Although rare, Furmark can potentially cause serious damage to your system. It puts some unrealistic loads on the GPU, specially the VRMs. Use with caution.
    New ROGer Array
    Oct 2019
    2
    Thanks for your note. I only use Furmark for couple of minutes. Do you think this short period can cause unrealistic loads on the GPU that may harm it?
    Thanks
    Mar 2018
    46
    492
    Quote Originally Posted by hanytadross View Post
    Thanks
    For short periods like that, not really. I would use something like Superposition benchmark.
