Results 1 to 3 of 3
    New ROGer Array
    Nov 2019
    6
    Zephyrus S GX535GW battery drain after shutdown
    Hi everyone,
    I bought the Asus Zephyrus S GX531GW-ES001T month ago and I have this problem of battery drain after I completly shutdown my laptop. I use the option of when your battery is at 60%, it does not charge anymore so, when I leave my laptop, battery % is at 60% for sure and sometimes, when I start it, the battery is under 5% mostly. I'm not sure is about that for fix my problem.
    I though is it an update of the bios maybe, I did it, problem still here.
    So, Should I send my laptop to Asus or can I fix this problem myself?
    Thanks a lot, have a good day!
    EDIT: btw do you know how to recover the system at just when you start it for the first time? I didn't found the asus soft for recover
    Sorry for my english
    New ROGer Array
    Nov 2019
    6
    Zephyrus S GX535 battery drain after shutdown
    Hi everyone,
    ROG Guru: Green Belt Array
    Nov 2012
    55
    572
    This post should be moved to the GX/GM/GU Series Gaming Notebooks Forum.
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
