problem with bios hdd encryption g75vw
lancelot494
Hello, a while ago I put a password on the bios for the mechanical hdd, I really don't know what happened, but it doesn't let me remove the password from the hard drive, and if I remove the hard drive from the computer (I connect it with usb to the computer or into other computer) I can't see any data on the disk because it's encrypted by the bios, I can't find a way to remove the password, does anyone know? This let me start windows by putting the bios key, but my intention is to buy an ssd and this mechanical hard drive take it to another computer. thanks
jdfrench3
Level 12
Take your laptop to a Best Buy. They have the means to delete the Master Password but you must prove proof of ownership first.
Good Luck
G752VSK, G75VW-3D, G51J, G1S
Homebuilt Windows Server
