How to recover Zephyrus GX531?
Ypeka
Hi everyone,
I want to recover my laptop Asus Zephyrus S GX531GW-ES001T and I didn't found the soft for this. Mostly of laptop have something like that, like Acer and not Asus? How can I recover my laptop with the recovery partition? I want to have my laptop like the first time when I started it
Thanks
Sorry for my english
Ypeka
Hi everyone,
Thanks
use windows tools.
type in the search bar "reset" your be prompted to recovery then choose "Get started"
You have to option to "keep you files" or "delete everything." this will reset to factory default.
83310
Pages 74 & 75 of your User's Manual (English), paragraph labeled "Performing A Recovery Option".
Launch "Settings" select "Update and Security".
Under "Update and Security" option, select "Recovery" then select the recovery option you wish to perform.
I believe the option you want is "Reset This PC".
Good Luck
This post should be moved to the GX/GM/GU Series Gaming Notebooks Forum.
G752VSK, G75VW-3D, G51J, G1S
Homebuilt Windows Server
