Results 1 to 4 of 4
    ROG Guru: White Belt Array Zeroed85 PC Specs
    Zeroed85 PC Specs
    MotherboardAsus Maximus XI Hero Z390
    Processor8700K 5Ghz
    Memory (part number)Dominator Platinum RGB 32GB 3466Mhz
    Graphics Card #1EVGA RTX 2080 Ti FTW3
    Sound CardSoundBlaster X AE-5
    MonitorAsus ROG PG349Q 34"
    CPU CoolerCustom cooling
    CasePhanteks Eclipse P600S
    Power SupplySeasonic Prime 1300W
    Keyboard Corsair K70 MK.2 SE
    Mouse Corsair M65 Elite
    OS Win 10 64 1909
    Jun 2017
    121
    Question Damaged USB 3.0 pin.
    Two pins on my new XI Hero's USB 3.0 connector were either bent or the cases USB 3.0 plug was faulty and bent them. Upon trying to straighten them one simply broke off. I believe the pin might be pin 10, the ID pin. Is this an over voltage protection pin or the pin for USB on the go (https://en.wikipedia.org/wiki/USB_On-The-Go)? What should I expect to not be working? If it is an over voltage protection that no longer works then that concerns me.
    Zeroed85 PC Specs
    Processor8700K 5Ghz
    OS Win 10 64 1909
    Jun 2017
    121
    The manual for the XI Hero says this is actually a ground pin...
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,583
    The specification for pin 10 is ID, not ground. It's an industry standard connector. I'm not sure what all ID does but I've read that if it's missing you will only get USB 2.0 speed.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Zeroed85 PC Specs
    Processor8700K 5Ghz
    OS Win 10 64 1909
    Jun 2017
    121
    Quote Originally Posted by xeromist View Post
    Well if I could be certain what that pin does I can decide whether it's worth the hassle of seeing whether the board can be replaced. Does anyone know?
