Apex x vs ıx difference Oddity
kaptanedi
I just upgraded x apex motherboard. Now I'm using xı apex. And all other equipment is the same. xı apex old ramler will not work properly. F4-4000C18D-16GTZ travelers. Xmp n1 18-19-19-39 1t profile never turns on the system gives 7f error only 3600mhz 18-19-19-39 1t opens. And the 4000mhz is opened at 18-19-39 2t. No overclocking is stable. But the previous x apex would open seamlessly. The newer version is to take the motherboard and get worse results. I'm also playing apex legends. Aida64 vs aisuite vs hwboot 3. Part software if I install the system in the game I'm experiencing stuck. In almost all games. The system is normal when not installed. First time I met. What could be the problem?
kaptanedi
Any ideas?
