ROG G731GU battery heats up while charging
CyberNinja_01
G731GU battery heats up while charging.
Is this normal?
10 REPLIES 10
jdfrench3
Level 12
The battery should heat no more than the charging brick. There should be little heat on either battery or charging brick, if left overnight, plugged-in.
G752VSK, G75VW-3D, G51J, G1S
Homebuilt Windows Server
It was just charging for one hour and it was heating
Was the laptop in use or simply powered-off and charging brick plugged-in to the wall?
It was in use but idle
What is the battery condition (Icon in lower right - percentage)?
It started heating at about 50% till 95% thats when i unplugged it
So, you were gaming with the laptop plugged-in and your battery dropped to 50% and then charged to 95% before you unplugged the charging brick?
What the heck are you gaming that would cause drain of 50% of your battery? No wonder your battery is hot. I don't think you have a problem with your battery but perhaps a problem with your settings while gaming.
Good Luck
No no i wasn't gaming, i was working on the laptop with out charging then i started charging at about 30%, then the battery started heating at 50% till 95% where i unplugged it.
I was using Word and PowerPoint thats it
