hereo viii wont boot Code 00 no other codes
comet424
so I came home and wasn't able to use computer.. computer was on but nothing... I rebooted nothing.. noticed Code 00
I pulled video card ram power supply cmos battery.. tried the holding power button to drain any residual power tried the button on the back for cmos flashback.. nothing.. Its happened once before and I hit the switch cmos settings button and that fix it.. I try that now both options get Code 00
im thinking its a burned out cmos chip not 100% sure anyone else have this error
comet424
also I ordered several years ago a bios chip for my formula IV board can I swap it out to test or will it screw the board... as im stuck I thinking the eprom is cooked not sure
comet424
I know probably wouldn't work I just wanted to see if it post something... as I think its done... anyone else replaced the chip before
Is the CPU light red as well?
Typically Qcode 00 means the CPU is not initialising. While that is simple, the solution is not so simple, as it can be many things.
