12-13-2019 09:26 AM - last edited 3 weeks ago by ROGBot
12-19-2019 12:15 AM
Saracino wrote:
I bought a 16Gb RAM stick (Crucial CT16G4SFD8266 DDR4 2666mhz) and a 512Gb SSD NVME M.2 and installed both in my Zephyrus S GX502GV to upgrade the total RAM and storage capacity to 32Gb and 1Tb respectively and activate dual channel RAM.
After that I went to turn on my PC and nothing happened.
Now it is totally dead, it doesn't beep, fans doesn't spin and if i connect the power cable, charging light doesn't turn on.
I removed first the new RAM module and then also the SSD (leaving the other old ssd and RAM), tried again, but the laptop doesn't boot, and all the indicators are off.
Any advice on what could have happened?
How can i fix this ?
12-19-2019 07:09 PM
12-20-2019 07:05 AM
titanfallking wrote:
Did you unplug the battery before working on it? Did you wear an ESD bracelet? ESD is real and you may have fried a fragile component on the motherboard.
