Results 1 to 4 of 4
    ROG Member Array
    Dec 2019
    8
    Rosewill RGB fan hub
    I have a x570-E with a Rosewill ATX Mid Tower Gaming PC Computer Case, the CULLINAN V500 RGB. It comes with a preinstalled rosewill fan hub and a switch on the front to control fan speeds.
    My conundrum is how can I connect to fan hub to the motherboard for aura sync to function.
    Downloading the fan hub manual indicates that I should be able to plug in a micro 3 pin female to a port on the hub and voila. But the rgb cable that comes with the board is a male and larger, also the speed switch on the front is plugged in that port. The hub also has two open led ports that are micro 4-pin male plugs.
    Curious if anyone here has encountered this issue and has any idea. I can't seem to find any cable resembling that which they advertise with their fan hub package. Or any that I think would work, And my only idea is to wire the two cables in to the same plug and hope everything goes according plan.. good or bad idea?
    Miniatura de Adjuntos Miniatura de Adjuntos JPEG_20191216_000413_3154716097712516501.jpg
    ROG Member Array
    Dec 2019
    8
    Update. New question
    Different questions.
    How can I connect the motherboard to the hub to address the individual fans? A 4 pin fan header? I dont think a rgb header will give me the option of fan speed. Yeah the leds will show on arua but the fan speed??
    Rosewill technical support is offering me a fan hub package to upgrade or use the parts I need and send it back. But still unsure of how to address the issue. Any ideas?
    New ROGer Array BattouZen PC Specs
    BattouZen PC Specs
    MotherboardAsus ROG Strix Z390-E
    ProcessorIntel i5-9600KF
    Memory (part number)G.Skill DDR4-3200 O.C.
    Graphics Card #1Asus ROG Strix GTX 1080 A8G
    MonitorSamsung Odyssey G5 27"
    Storage #1Samsung NVMe 970 EVO 500g
    Storage #2Kingston UVG300 240g
    CPU CoolerAIO Cooler Master
    CaseRosewill
    Keyboard Corsair K95 Platinum RGB
    Mouse Corsair Scimitar Pro RGB
    Headset Bose AE Soundlink
    Mouse Pad Corsair MM700 RGB
    Headset/Speakers Bose Solo SoundBar
    OS MS Win10 Pro
    Network RouterLinksys WRT1900AC
    Accessory #1 AfterGlow Xbox One Prismatic Controller
    Apr 2020
    1
    I'm having the exact same issue.. Did you come up with a workaround?
    ROG Member Array
    Dec 2019
    8
    After a few messages to both rosewill and asus.
    Quit while your ahead. This companys fans and case are incompatable.
Tags for this Thread
