Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    New ROGer Array
    Dec 2019
    8
    possible CPU throttle?
    Hey
    Just put together my new PC, see below for specs.
    I've done countless test to make sure my PC perform as it should, and it seems it does it, yet the other night when i was trying out Fallout 76, 2 of the cores suddenly dropped to 800mhz for a split second and back to normal 4.7ghz again, i got no signs of throttle other then it looks like one.
    Now in my opinion Fallout 76 is not big power hungry game, and i am able to run prime95 for hours without this problem, so i'm really confused what is going on.
    And other games does not seem to do this either.
    In HWINFO64 i see this VR VCC Temp. (SVID) i would assume this is the VRM temp. it stays around 30c-40c
    Windows 10 Power plan is set for Ultimate Performance so all the cores are unparked.
    Everything in bios is default with exception of the unlocked power.
    The CPU runs 30c idle, and 40-60c in games depending on the game. Prime95 full load i get around 89c. And that is running 4.7ghz all cores.
    I recently did a bios update to 1401.
    Anyone have any idea whats going on here?
    MB: Z390-F Gaming
    CPU: 9900K with a NH-D15 (2 fans)
    RAM: 32GB G-Skill
    GPU: 2080Ti
    PSU: Coolermaster 1000watt silent pro
    I finally found a solution this problem: https://github.com/IIWDTI/Decaffeinated
    ROG Guru: Orange Belt Array
    Jan 2011
    20
    462
    Change your Power Options in the Control Panel and see if that fixes it for you. Change it to Maximum Performance and see what happens for you.
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / NZXT Kraken X62
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    11
    311
    I was getting some temporary throttling the first week I started gaming with my new build. The solution was to change the power option as the above poster mentioned. That either helped or coincided with the problem disappearing. I have since then switched back to "Balanced" and have had no throttling since, except for after installing some Windows updates. It seems to me that some of those updates must involve scanning or something like that--and that these updates are the likely cause of any throttling.
    New ROGer Array
    Dec 2019
    8
    Quote Originally Posted by KILLER_K View Post
    Quote Originally Posted by Super Gnome View Post
    thanks for the input guys, unfortunately it still does it in Highest performance mode in Windows power plan settings.
    its really weird only this game does it.
    i'm gonna do some more testing, if anyone find a solution please feel free to contact me.
    ROG Member Array
    Jul 2013
    13
    Salut ,si cela ne le fait qu'avec Fallout 76 alors ton 9900k n'est pas fautif mais bien le jeux !
    New ROGer Array
    Dec 2019
    8
    Quote Originally Posted by tousmic88 View Post
    Translation: "Hi, if it does with Fallout 76 then your 9900k is not at fault but the game!"
    That was my first assumption also, but i do not think games/programs work on such a level were they can change the speed of a single core, and only for a split second, i might be wrong though.
  7. #7
    Mar 2019
    11
    311
    If it is the game that is causing the throttling, that makes sense. If any software is causing problems simply lower your in game settings. Starting with FPS and other graphics settings this will really help. And it's very likely you won't noticeably change the quality of the game play even if you limited your FPS to as low as 30 (which I do--and my CPU and GPU are running at extremely healthy temperatures, to boot).
    You might also consider running HWMonitor to see what your max temperatures are reaching. In my rig, with its well below max settings, a lot of days the GPUs never go above 52 degrees. The CPU is maxing out at 62, but is very rarely above 40.
  8. #8
    ROG Guru: Yellow Belt Array Carlyle2020 PC Specs
    Laptop (Model)amd4000 for sure next time
    MotherboardAsus Maximus XI APEX
    Processorgaming9900ks/@5.1 avx -1 / adaptive auto vcore/LLC5/AC+dc 0.01/TVB on/all power savings on
    Memory (part number)Corsair LPX 4000 CL19@16.17.28/300/2T/ 1.42 volt
    Graphics Card #1Gainward RTX 2080Triple/tempsense on Displayport needed
    Sound CardXonar STXII mods:3xLME 49720NA
    MonitorLG 38GL950G / -HDR / +madVR
    Storage #12TB 970evo plus nvme
    Storage #21TB 960evo nvme +2x 1tb evo 860 hw-sata-raid
    CPU CoolerNoctua NH-D15 /pull+spacers/so not 100%
    CaseSilverstone FT2 dampened up the wazoo
    Power SupplySeasonic TX-850
    Keyboard Cherry KC 1000 on top of a cherry MX1 for ergonomics :)
    Mouse MX Master 3
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers A250 / cause LG was stingy
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off
    Accessory #3 4 bay fantec /10tb red/+scrap
    Mar 2018
    17
    142
    800Mhz is the lowest power saving throttle setting if CPUs are not being used.
    That might be a clue ?!
    I really am not sure.
  9. #9
    New ROGer Array
    Dec 2019
    8
    currently everything is running perfect actually no stutter or fps drop at 60fps locked, my only concern is the fact HWInfo is telling me the CPU cores are dropping to 800mhz for less then a second from time to time. It is unusual behavior, and the fact i'm running High performance mode, tells me something weird is going on.
  10. #10
    Mar 2019
    11
    311
    Quote Originally Posted by NewGamer2020 View Post
    I had the same thing--as mentioned above. Another thing I did was look at Task Manager. Sometimes your rig can be running stuff you don't need. You might have installed something that is running from start up even though you don't need it.
