Results 1 to 5 of 5
    ROG Member Array
    May 2015
    5
    M.2 compatibility
    I just bought a ROG STRIX B450-F GAMING and a SSD Western Digital of 240 GB, M.2 SATA III (6Gb/s). The MoBo did not detect the drive.
    I was told by the store that it was not compatible. I went to the MoBo webpage to check the compatibility and it states 1X M.2 Socket 3.
    I had to get a 2.5 SSD and I want to use a M.2. I am using a Ryzen 7 3700X processor. Can anyone help me letting me know what M.2 SSD's are compatible?
    I appreciate the reply.
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    389
    That is not a M key m.2 is why it does not work
    https://rog.asus.com/articles/guides...hich-is-which/
    ROG Member Array
    May 2015
    5
    Thanks for the response. So basically I need a NVMe drive, the one that has 5 connectors only.
    So This one would be compatible with my MoBo?
    I'm sorry but I'm a bit confuzed with this thing since is the first time I have to deal with it.
    Thanks for the reply.
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    389
    ROG Member Array
    May 2015
    5
    Thanks for the reply. I really appreciate it.
    Have very nice holidays.
