Results 1 to 2 of 2
Thread: Post code 7F
    New ROGer Array
    Dec 2019
    1
    Post code 7F
    Hello guys, do you need help? I played the game and post code 7F crashed and my computer restarted Asus z390 extreme motherboard Processor i9 9900k in overclocked to 4800mg RAM g.skill 4400 took 4000mg what could be the problem? In overclocked RAM?I'm sorry I speak English bad
    ROG Guru: Yellow Belt Array XYchromosone PC Specs
    MotherboardASUS Maximux XI Extreme [BIOS 1401]
    Processori9 9900KS
    Memory (part number)G.Skill Trident Z RGB CL17 3600MHz 32GB [4x8]
    Graphics Card #1ASUS ROG Strix Gaming GTX 1080Ti 11GB
    MonitorAOC AGON AG271QG 27" 144Hz-165Hz OC
    Storage #1Samsung 970 Pro NVMe 1TB M.2 SSD
    CPU CoolerThermaltake Floe Riing 360 Premium AIO
    CaseFractal Design Define R6 Black
    Power SupplyCorsair AX1600i
    Keyboard RAZER Blackwidow X Tournament Chroma
    Mouse RAZER Lancehead [ambidextrous] Chroma
    Headset Sennheiser RS165 Wireless
    Headset/Speakers Sennheiser CX 100 inner ear headphones
    OS Windows 10 Pro x64 + Ubuntu Studio 19.04
    Network RouterASUS DSL-AC68U on ADSL2+, Technicolor DJA0230TLS Gateway, Netgear Cable Adapter CM450
    XYchromosone's Avatar
    Dec 2015
    30
    249
    I guess you already know that 7A to 7F q codes are reserved for future AMI DXE codes. So that is of no real help here. What RAM voltage are you using? If it's from the XMP profile it would be 1.35V @ 4000MHz. If so try raising it to 1.4v and see if that helps.
