Results 1 to 6 of 6
    ROG Enthusiast Array bogdi1988 PC Specs
    bogdi1988 PC Specs
    Laptop (Model)2019 Macbook Pro 15.6 / Pixelbook
    MotherboardAsus Zenith Extreme II
    ProcessorAMD Threadripper 3970x
    Memory (part number)F4-3600C18D-32GTZN x2
    Graphics Card #1AMD Radeon VII + EKWB waterblock
    MonitorSamsung 49" CHG90
    Storage #12x MyDigitalSSD BPX Pro 500GB RAID 0
    Storage #24x Sabrent Rocket 4.0 1TB RAID 0
    CPU CoolerWatercool Heatkiller IV
    CaseCorsair 1000D
    Power SupplyCorsair AX1600i
    Keyboard Ergodox EZ Glow
    Mouse Corsair Ironclaw
    Headset Sennheiser Momentum 3
    Mouse Pad Razer Goliathus Speed Extended
    Headset/Speakers Samsung HW-K460
    OS Windows 10 Pro for Workstation
    Network RouterASUS GT-AX11000
    Jul 2017
    11
    44
    Zenith II Extreme intermittent device detection
    Running into this weird issue with my system.
    Zenith II with 3970X, 6xNVME (2 in DIMM M.2, 2 in M.2.1 and M.2.2 and 2 in ASUS Hyper M.2 x16), Corsair 1000D case and AX1600i PSU.
    Bios is 702, Fastboot is disabled, NVME RAID enabled, PCIe slot 3 set in RAID mode for Hyper card.
    During reboots, randomly some devices are not detected. Either the DIMM M.2 NVMEs, or the USB devices for the 1000D or AX1600i PSU. Doing a complete power off and power on, all devices are detected OK.
    Anyone else running into this issue?
    ROG Junior Member Array
    Sep 2012
    4
    Quote Originally Posted by bogdi1988 View Post
    Yep, not in the same way, it just does not let me boot with 3 GPUs or more. On X399, I can boot with 4 GPUs flawlessly.
    ROG Member Array
    Jan 2020
    11
    Running into a similar issue with 5 M.2 installed.
    DIMM M.2 are always detected but 3 other drives can be missing.
    However this is happening ONLY after exiting EUFI with Save and Restart option.
    In all other cases all 5 drives are detected properly.
    BIOS version is 0702
    Oct 2014
    2
    I have the same problem with one or more drives not detected on restarts, but always detected on cold boots. It usually happens when restarting after saving BIOS changes, but it has happened restarting for Windows or application updates, too.
    Jun 2013
    26
    I have the same exact issue but it's limited to a single m.2 drive.
    New ROGer Array
    Sep 2020
    3
    Quote Originally Posted by nyxagamemnon View Post
    Same issue - on a cold boot, I’m fine. *But on a warm restart/reboot, I am sometimes stuck in UEFI since it doesn’t see the NVMe. * Complete power off and power back on and I’m fine. *At least it isn’t just me - which means a bug that has a higher chance of getting fixed!
