Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Power questions
  1. #11
    Timstone
    Guest
    I'm going to eliminate those two 2x1 connectors, will be easy. I'll keep you guys posted!
    Oh, how do I add to the Rep power of you two? I tried clicking the small "star" button next to the "Report post" button, but I don't see effect immediately.
  2. #12
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,887
    LOL, if you want to remove the two extra pins I suppose you can but keep in mind that you won't be able to use that PSU if you ever upgrade to a card that needs those two pins.
    Yes you use the star button and you get a popup text box where you can add a comment(optional) and click submit. If you aren't getting the popup you might want to restart your browser or try a different one.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  3. #13
    Timstone
    Guest
    Well, since I document all the connectors very carefully, it will be easy to replicate them. No sweat.
    I clicked the star and filled out the small popup, but still no increase in the Rep of the both of you. If I hit it again, another popup says I have to spread Rep first before I can give it to you two guys again. Sorry.
  4. #14
    TeamROG Folding@Home Array ottoyu34 PC Specs
    ottoyu34 PC Specs
    MotherboardMaximus IX Hero
    ProcessorIntel Core i7 7700K
    Memory (part number)Trident Z RGB (F4-3600C16D-16GTZR)
    Graphics Card #1ROG Strix GTX1080 Ti OC
    MonitorLG IPS LED 27"
    Storage #1Samsung SSD 850 PRO 1TB
    Storage #2Crucial MX300 525GB SSD
    CPU CoolerCorsair Hydro H115i
    CaseCorsair Obsidian 750D Airflow Ed.
    Power SupplyEVGA SuperNOVA 750 G3
    Keyboard Corsair Vengeance K65
    Mouse Logitech G502
    Mouse Pad Razer Destructor
    Headset/Speakers Logitech Z-2300 2.1
    OS Windows 10 Pro x64
    Network RouterAsus RT-N66U
    ottoyu34's Avatar
    Apr 2010
    805
    No worries it should do it, I see the record in my settings but not yet added under "Rep Power"
  5. #15
    ROG Member Array RudeRaptor's Avatar
    Jan 2011
    16
    Quote Originally Posted by ottoyu34 View Post
    For regular usage, you only need to plug in your EPS 8pin power to the EATX12V_1.
    Sorry Tim for posting on your thread. But I have few question for ottoyu...
    For the moment, I'm only going to run 1 GPU w/no overclocking(GTX580). So do I still need to plug in to the EZ_Plug1 & 2??
    Also my PSU has an EPS 8pin power connector & EPS 2x4 power connectors that have the same specs as the 8pin power connector. So should I connect both EPS 2x8pin connectors to both EATX12V_1 and EATX12V _2? Or just EATX12V_1?
    No overclocking at the moment either. That and SLI will be later in the future.
  6. #16
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,887
    You won't need to connect any of the extra connectors. The extra EPS connector is really only needed under EXTREME overclocking scenarios (ie requiring phase change).
  7. #17
    Jan 2011
    16
    Quote Originally Posted by xeromist View Post
    Thank you very much!!
Similar Threads
  1. A few questions before I pull the trigger...
    By me010698 in forum ROG Gaming Notebooks
    Last Post: 11-26-2011, 03:30 AM
  2. AC Power Supply Problem
    By thumper64 in forum ROG Gaming Notebooks
    Last Post: 12-30-2010, 03:28 AM
  3. M4A89GTD PRO Power Supply Question
    By davidpai in forum Other Series Motherboards
    Last Post: 12-25-2010, 08:31 AM
  4. Memory questions for Sabertooth X58
    By sloweb in forum Other Series Motherboards
    Last Post: 12-03-2010, 12:22 PM
  5. ATX Power Connectors
    By zfrenchpig in forum Other Series Motherboards
    Last Post: 11-18-2010, 11:37 PM
Tags for this Thread
