Results 1 to 3 of 3
Thread: NVMe M2 Problem
    ROG Member Array
    Feb 2015
    11
    NVMe M2 Problem
    Hi and happy new year, I have a spare PCIe slot on my Maximus VII Formula m/b and decided to treat myself to a Samsung 970 EVO Plus NVMe M2 and an adapter. Windows had no problem finding it, but no joy in the bios (I was hoping to boot from it). Is there any way to fix this or am I stuck with a very fast storage. Thanks for any help....Ron.
    New ROGer Array
    Sep 2019
    1
    hi.
    i have the same exact problem. there is NO real answer to this issue. Its driving me crazy.... i cant get my NVME ssd to work (brand new).
    it worked for a while and then suddenly stopped working. from time to time it works but its super random. now my sata SSD is not showing in BIOS aswell and its super frustrating. both my SSD and motherboard are new. Sata SSD is older but it was working fine with my previous motherboard. im disappointed in ASUS for not providing with a solution here.
    ROG Member Array dantess PC Specs
    dantess PC Specs
    MotherboardASUS ROG STRIX Z390-E GAMING
    ProcessorIntel® Core™ i5-8600K
    Memory (part number)Crucial Ballistix Sport 32GB (2x16GB) DDR4 2400MHz
    Graphics Card #1ROG-STRIX-RTX2080-O8G-GAMING
    MonitorSAMSUNG 55Q6FN
    Storage #1WD Black SN750 NVMe, 500GB, M.2
    Storage #2Intel 545s Series 256GB
    CPU CoolerSilentiumPC Navis EVO ARGB 280
    CaseSilentiumPC Armis AR7 TG RGB
    Power SupplyCorsair CMPSU-750TX
    Mouse Asus ROG Gx860 Buzzard V2
    OS Windows 10 Pro v, 1909
    Network RouterASUS RT-AC66U B1
    Mar 2011
    6
    Hello and Happy New Year!
    Here's what you should do.Try to make a Windows bootable usb stick in GPT mode with Media Creation Tool. Of course, you will start the BIOS in UEFI mode and you will be able to install Windows without problems on the NVMe M2 SSD.
    Before starting the installation of Windows on the NVMe M2 SSD, format it.
    I hope this will help you!
