Results 1 to 6 of 6
    ROG Enthusiast Array
    Oct 2011
    11
    37
    Throttlestop and power supply
    I have a g74sx and it is the first gaming laptop I have owed and when I am playing games for a couple of hours I noticed that the power supply brick gets pretty hot and I am just wondering if this is normal, also I started using throttle stop a few months back and last night I noticed after a couple hours of crysis that the brick was even a little hotter than without it , I guess what I want to know is it bad for the power supply using throttlestop..other than being fairly hot to the touch there has been no burning smell or any other problems just don't want to destroy my power brick.
    ROG Guru: White Belt Array n1ghtl1fe's Avatar
    Dec 2011
    17
    95
    "WARNING: ThrottleStop is an Intel Core 2 and Core i performance monitoring and modification tool. Some manufacturers throttle CPU performance to protect their motherboards or the power adapter from being damaged so keep that in mind before making any changes. Using ThrottleStop to overclock or over volt your CPU or to disable a laptop manufacturer's throttling scheme may damage your computer and is at your own risk. "
    This quote is from the creator of throttlestop, I personally dont use it unless theres a game that really suffers from throttling. It pulls more power from your brick so it heats up faster = shorter life. I read elsewhere that purchasing a higher output power supply could remove this problem though.
    source: http://forum.notebookreview.com/hard...top-guide.html
    G75
    -i7-3610QM -16GB DDR3
    -256GB Patriot SSD -Nvidia GTX 670M 3GB
    -1TB HHD Storage
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,559
    Quote Originally Posted by tkd_ron View Post
    I think the bricks are spec'd pretty close to the maximum draw of the machines and that there isn't much breathing room. Most likely you will be OK as long as the brick is able to radiate enough heat but it might have an overall shorter life. I would avoid setting it among blankets or other areas where there is inadequate air circulation. Also, as was already mentioned you could buy a bigger brick which would leave more head room and operate closer to optimal load.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Oct 2011
    11
    37
    Thanks guys for the info , if I wanted to get a bigger power supply what would be some suggestions as to wattage and brand? thanks
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    301
    7,559
    Not sure I have any references handy. I'm pretty sure people have changed on the G74 so I'd say do some searches on the forum here and you might find something.
    ROG Member Array
    Feb 2012
    tkd_ron look as this post from Chastity@ASUS, I think that is what you are looking for.
    http://rog.asus.com/forum/showthread...ll=1#post77777
