Results 1 to 7 of 7
    ROG Guru: Green Belt Array Rob W. PC Specs
    Rob W. PC Specs
    MotherboardRog Asus Rampage vi extreme
    ProcessorIntel i9-7980x Oc 4.6ghz 24/7
    Memory (part number)64 gb GSkill 3600mhz (8x8) 15,15,15,35
    Graphics Card #1nvidia Titan V + ekwb custom loop
    Graphics Card #2nvidia RTX 2080Ti on air.
    Sound Cardonboard?
    MonitorIAsus PA329Q 4k 32"
    Storage #1samsung SSD 960 EVO 250 GB. M2 nvme
    Storage #2Samsung ssd 970 evo 500gb m2 nvme
    CPU CoolerEKwb custom loop
    CaseCorsair Obsidian 900
    Power SupplyCorsair HX1200i 1200w
    Keyboard Logitech G910 orion spark
    Mouse Logitech G502 Proteus core
    OS Win 10
    Network Routerbt infinity super fast.
    Accessory #1 Seagate Barracuda 2 TB HDD
    Accessory #2 Aqeuaro 6xt fan controller
    Accessory #3 Intel Optane 280gb
    Dec 2015
    104
    501
    Water block for the R6E Omega?
    I had to return my R6E and asus are sending me an Omega as replacement but I don’t know if the monoblock from the extreme will fit the same as from what I can tell the vrm’s are different.
    Can anyone enlighten me if this will fit, ? other than that I wait till it’s delivered Monday and physically compare it.
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71
    MotherboardROG Maximus IX Extreme
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 140 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 1909
    Network RouterGeneric
    Accessory #1 ROG Aura Terminal
    Accessory #2 ROG 10GB Express
    Accessory #3 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Jan 2016
    182
    if this will fit
    Nope!
    R6E:
    R6E Omega:
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    501
    Thanks for that @pndiode
    Now all I’ve got to do is find who has it in stock.��*
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth & x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 & Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block & Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 & EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum & Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller 4 Pro copper plexi/Optimus Foundation copper plexi
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 Mayhems 3/8-5/8" clear soft tubing
    ThrashZone's Avatar
    Oct 2017
    23
    370
    Stock air cooler is fine on the omega unless you just go for looks on a build mono blocks have been proven inferior to separate vrm and cpu water
    combinations.
Name:	optimus foundation.JPG
    Otherwise there is a new water block manufacture based in Chicago putting out an excellent water block optimus foundation
    Also performance pc stocks them too with ocn discount codes around
    https://optimuspc.com/products/found...pu-block-intel
    I got one temp spread is pretty good better than heatkiller 4 pro and makes ek offering look old and pitiful same as heatkiller 4 pro made them look
    Optimus has a huge finned cold plate area 3/4" longer and 3/16" wider than just the heatkiller
    My test others above using the optimus foundation with just nt-h1 on it other tests were using mx4 2019 paste
    https://www.overclock.net/forum/61-water-cooling/1733810-optimus-waterblock-59.html#post28261682
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    501
    @ThrashZone looked at link and decided to go for the optimus as vrm’s have there own fan, I’ll see how it goes.
    Optimus ordered, thanks.*
    Purchased the same as the link.*
    ThrashZone PC Specs
    ThrashZone's Avatar
    Oct 2017
    23
    370
    Quote Originally Posted by Rob W. View Post
    You won't regret it
    It's darn good block
    They will likely do vrm blocks to at some point so fear not
    As you probably noticed they have some nice other goodies and will have radiators too in 6 months plus dual D5 pump bases .....
  7. #7
    Rob W. PC Specs
    Sound Cardonboard?
    OS Win 10
    Dec 2015
    104
    501
    It’s just been shipped.
