Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Junior Member Array onurozokten PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorIntel i7 8700
    Memory (part number)F4-3600C16D-16GTZNC
    Graphics Card #1ROG STRIX 2080 TI
    MonitorAoc E2752V LED Monitör
    Storage #1Samsung 840 Evo 250 Gb
    Storage #2Samsung 970 Evo 1 TB
    CPU CoolerCooler Master Seidon 120M
    CaseCooler Master Haf 942 X Black Edition
    Power SupplyCooler Master RS720 Silent Pro 2
    Keyboard Asus Rog Strix Flare
    Mouse Razer Abyssus 2000
    Headset Asus Rog Delta
    Mouse Pad Standart Mouse Pad
    Headset/Speakers Logitech Z906
    OS Windows 10 Pro
    Network RouterAsus RTAC3200 Router
    onurozokten's Avatar
    Nov 2017
    2
    Angry Pls Help Armoury Crate Problem
    I updated the latest version bios I did a clean installation but I can't access the settings.
    Should I install Armory 2?
    2nd question: Ram and Graphics Card does not work synchronously
    S:Windows 10 Pro
    Hardware:
    Maximus XI Formula
    Rog Strix Flare
    Rog Delta
    Asus o11G Strix 2080 TI
    ROG Guru: Orange Belt Array
    Apr 2019
    19
    280
    Could be a server problem for your region because the other guy from turkey has the same problems. I would contact the support*
    New ROGer Array
    Aug 2019
    16
    Quote Originally Posted by Re@per View Post
    support wont do anything. i live in greece and they just tell me its not their problem
    Apr 2019
    19
    280
    Have you checked the support page for your devices maybe a firmware update is missing?
    New ROGer Array areserhat PC Specs
    areserhat PC Specs
    MotherboardRog Strix X570 E
    ProcessorAMD Ryzen 3700x
    Memory (part number)Kingston 2933MHZ
    Graphics Card #1Rog StrixRx580
    MonitorAOC C24G1
    Storage #1Samsung M2 970 250gb
    Storage #2Samsung M2 970 Plus 500gb
    CPU CoolerRog Ryujin 240
    CaseCorsair Crystal 680x
    Power SupplyRog Strix 750W PSU
    Keyboard Corsair K95 RGB Platinium
    Mouse Rog Gladius Origin
    Headset Steelseries Arctis 7
    Mouse Pad Steelseries QCK Prism
    Headset/Speakers Logitech Z533 White
    OS Windows 10 Pro
    Accessory #1 Rog Terminal
    Accessory #2 Rog Led Strips
    Oct 2019
    8
    Arrow
    As you said i have the same problem and i am from Turkey :/
    But interesting one our hardfware is also different. So why this problem exists still not know i did more then 6 clean Windows install i did all the drivers updated i tried all different techniques. i tried reinstall uninstall clear cmos etc. i tried to install service packs inside of armoury crate folder. i tried reinstalling everything. But no solution since 2 months no update shown because of that i dont able to manage my ryujin, gladius II, or motherboard (im using Ai süite) but i want to use armoury but this stupid program doesnt let us to manage :/
    OS Windows 10 Pro
    Nov 2017
    2
    I have the most recent BIOS
  7. #7
    areserhat PC Specs
    MonitorAOC C24G1
    OS Windows 10 Pro
    Oct 2019
    8
    Angry
    Quote Originally Posted by onurozokten View Post
    Maybe Asus should do like AMD or Nvdia.
    Know problems with Armoury Crate
    Will be fixed with next update
    Or someone from their software team should visit this forums and try to help people or convince them about they are working on this issues. so since 2 months i realized that these are Asus forums but no one from their technical team assist people or joining these conversations.
    Probably after 3 years i am going to buy another brand for that reason.
  8. #8
    Apr 2019
    19
    280
    Well if u did a fresh install win 10 and have turned on armoury crate in bios. it should work other else it can only be a server issue
  9. #9
    ROG Junior Member Array Ruamoko PC Specs
    Ruamoko PC Specs
    Laptop (Model)ROG G752VSK OC Edition (7th Gen Intel Core)
    MotherboardAsus ROG Strix Z390-H Gaming
    ProcessorIntel Core i9-9900K, 4700 MHz
    Memory (part number)Kingston HyperX KHX2800C14D4/8GX (2x8GB)
    Graphics Card #1ROG-STRIX-GTX1080TI-O11G-GAMING
    Sound CardCreative Sound BlasterX AE-5
    MonitorAsus ROG Swift PG348Q [34" IPS LCD]
    Storage #1Samsung SSD 850 EVO 500GB
    Storage #2ST31000524AS (1 TB, 7200 RPM, SATA-III)
    CPU CoolerCORSAIR H110i
    CaseCORSAIR CARBIDE SERIES AIR 540
    Power SupplyCORSAIR HX850i
    Keyboard ROG STRIX FLARE
    Mouse Logitech G900
    Headset Sennheiser GSP 600
    OS Microsoft Windows 10 Pro (1909)
    Apr 2017
    4
    And I am from Israel and I have absolutely the same problems with ASUS software!
    Motherboard: Asus ROG Strix Z390-H Gaming
    Processor: Intel Core i9-9900K, 4700 MHz
    Memory: Kingston HyperX KHX2800C14D4/8GX (2x8GB)
    Graphics Card #1: ROG-STRIX-GTX1080TI-O11G-GAMING
    Sound Card: Creative Sound BlasterX AE-5
    Monitor: Asus ROG Swift PG348Q [34" IPS LCD]
    Storage #1: Samsung SSD 850 EVO 500GB
    Storage #2: ST31000524AS (1 TB, 7200 RPM, SATA-III)
    CPU Cooler: CORSAIR H110i
    Case: CORSAIR CARBIDE SERIES AIR 540
    Power Supply: CORSAIR HX850i
    Keyboard: ROG STRIX FLARE
    Mouse: Logitech G900
    Headset: Sennheiser GSP 600
    OS: Microsoft Windows 10 Pro (1909)
    At first, the AURA stopped working after the update. Nothing helped - I had to reinstall the Windows and then automatically (apparently the BIOS of the motherboard) installed ASUS Armoury Crate and:
    1. Armoury Crate now says that I do not have AURA devices which could be controlled. But I do!
    2. Armoury Crate does not see my ASUS video card at all! (not even listed)
    3. Armoury Crate constantly requires updating - updating - and again says that you need to update and so on and on! LOOP
    For a week I read various forums and topics devoted to excellent software from ASUS and tried to apply all the tips that I came across:
    1. Clean Windows installation on a clean SSD and updated.
    2. Wherever required - BIOS and drivers updated to the latest versions from the manufacturer’s sites.
    3. Using latest versions of all software.
    4. Cleaning the registry and reinstalled ASUS software.
    5. Deleting different files and folders according to user advice.
    6. Dancing a shaman dance around the computer and sacrificed to the computer gods...
    Nothing helped...
  10. #10
    ROG Enthusiast Array TheEternaL PC Specs
    TheEternaL PC Specs
    MotherboardAsus ROG Rampage V Edition 10
    ProcessorIntel Core i7-5930K
    Memory (part number)32GB HyperX Predator 8x4GB 2133Mhz
    Graphics Card #1Asus ROG Strix GTX 1080 Ti
    MonitorSamsung Odyssey G7
    Storage #2M.2 SSD Samsung 970 Pro 512GB
    CPU CoolerCostum EK Water Cooling
    CasePhanteks Enthoo Evolv X
    Power SupplyNext Buy Asus ROG Thor 850 Watt
    Keyboard Asus ROG Strix Flare
    Mouse Asus ROG Gladius II
    Headset Asus ROG Delta
    Mouse Pad Next Buy Asus ROG Balteus
    Headset/Speakers Next Buy Asus ROG Magnus
    Accessory #2 Asus ROG Aura Terminal
    Accessory #3 Speakers Edifier 2730DB
    TheEternaL's Avatar
    Dec 2016
    11
    68
    I don’t know how it is with you, but it certainly doesn’t work for me as I wanted but it works.
    It happens after a reboot or start from a cold one that does not immediately start.
    It may turn on immediately, or maybe 5 minutes or maybe it will not turn on at all.
    Asus ROG Protucts:
    Asus ROG STRIX GTX 1080 Ti
    In BIOS, I do not have ARMORY CRATE.
    Somehow it works.
    It works poorly.
Tags for this Thread
