Results 1 to 8 of 8
    ROG Member Array
    Sep 2013
    21
    building pcs is a pain
    is it just me that finds building a pc incredibly obsolete, those stupid 24 pin and 8 pin cables often causes you to bleed trying to connect them, not to mention the even more primitive connections of actual pins that you can literally bend from the smallest touch bye bye 400 dollar motherboard, why can't a standard be made maybe magnetically attached cables why not use the usb standard why do graphics cards still need extra cables i understand that they needed it in the past as they needed more power than motherboards were designed to deliver but now no theresn o excuse for it still being needed, why can't be building be simplified i am literally in pain in my finger for trying to squeeze the 8 pin cable in and connect it, why is both a 24 pin and 8 pin needed, why overcomplicate everything, and don't tell me a motherboard can't be designed to work just with a 24 pin cable or a simpler connection, yeard ago i had the idea of wireless fans that magnetically attach to the case using wireless power and still noone has done anything like that.
    ROG Member Array YabaX PC Specs
    YabaX PC Specs
    MotherboardRog Strix X570 Gaming-F
    ProcessorAMD Ryzen 3700X
    Memory (part number)G.Skill Tridentz Royal 3600 (OCed 3800)
    Graphics Card #1Rog Strix 1080 Ti OC
    Sound CardOnboard Supreme FX
    MonitorAsus MG278Q -27" Freesync - 1ms
    Storage #1Samsung 970 Evo Plus Nvme
    Storage #2Bunch of SSDs + 7 TB HDDs
    CPU CoolerCooler Master ML240R ARGB AIO
    CaseCooler Master Cosmos C700M
    Power SupplyEVGA G2 1000W Gold
    Keyboard Corsair K70 RGB
    Mouse Steelseries
    Mouse Pad Corsair RGB
    Headset/Speakers 5.1 Creative
    OS Windows 10
    Network RouterAsus RT-AC3200
    YabaX's Avatar
    Nov 2014
    13
    BRUH!!! just buy an extension cable and wire it to mainboard then wire the other end from the back.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,046
    Everything you are complaining about are standards. Without standards nothing would work together. New standards would mean billions in existing hardware no longer works. It would also mean any manufacturer trying a new standard wouldn't be able to sell its products to an existing install base. Perhaps a clean slate design would look very different but because the current standards still work there is no reason to change them.
    Also, yes it's just you. But feel free to start a company making proprietary adapters. Perhaps you can find a niche.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Nov 2019
    14
    100% agree with you. Thats why I buy a laptop. Portable and No Pain.
    ROG Guru: Brown Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardCrosshair VIII Dark Hero
    Processor5900X 4.6ghz All core 1.3V, 5ghz single DOC
    Memory (part number)Gskill NEO 3600 CAS 14 32GB (4x8)
    Graphics Card #1ROG Strix RTX 3080
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 980 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 980 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks 500A Mesh
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur Virtuoso
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    1,002
    No way I can agree. I love building PCs.
    First off, it is easier then most folks think. I find it entertaining how friends and family are awe struck when you say "yeah, I built that PC." It's really pretty easy and if folks knew just how plug and play the process is they would be far less impressed.
    Of course once you master the basic science of building a PC, then comes the art. The art of choosing the best components that work best together and compliment one another. Components well matched in price/performance with no glaring weak links or overkills. Then there is the art of PC aesthetics. It is rewarding to build a good looking system whether it is a full blown RGB disco, or stealth and understated. Finally the art of overclocking. Squeezing the most free performance out of the system merely by adjusting system parameters.
    When it all comes together the right way it is a very rewarding experience. Not much different then building a car, a house, or any other hands on project.
    If you can't be bothered by connecting a few cable, the PC hobby is not for you. Instant gratification is not as nearly as intense as a PC build that you put a little time and effort into. I only do a few builds a year for myself and my kids. I wish I could do more. I get bored with my systems after about 90 days and yearn to build a new one. Too bad my budget and available time do not allow it. Recently I've resorted to building "new" systems out of old parts just to do it. Nothing is as rewarding as that first boot up
    ROG Guru: Yellow Belt Array bobbagels PC Specs
    bobbagels PC Specs
    MotherboardRampage V Extreme (original)
    Processor5930 K
    Memory (part number)16 G Crucial Ballistix DDR4-2400 (2x8)
    Graphics Card #1Asus GTX 1080
    MonitorPG279Q
    Storage #1Samsung 950 Pro
    Storage #2Samsung 850 Pro- 500 Gb- W/D Cavier Black1 TB
    CPU CoolerSwiftech H-240 (push pull)
    CasePhanteks Primo
    Power SupplyEVGA SuperNova- 1000W 80+ P
    Keyboard G19s
    Mouse G700s
    OS Windows 10
    bobbagels's Avatar
    Nov 2014
    193
    Eh, I could think of a few things
  7. #7
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    1,002
    Cool
    After looking at your system specs, I can see why lol
  8. #8
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,125
    ZZcool, I don't have an issue with inserting the cables, and I have fat fingers. Honestly I don't see the issue. I agree with mdzcpa's comments above, it's about personal satisfaction with your accomplishment, and the thrill of the process itself. If that is a pain for you then you should be taking your credit card to Best Buy and buying something off the shelf.
    Davemon50
