Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    ROG Guru: Orange Belt Array
    Jan 2011
    20
    462
    Asus Aura Teams up With Corsair ICUE
    Asus has now teamed up with Corsair to let their ICUE software control the boards. Simply install the latest Aura Sync but don't run it. Head over to Corsair's forum and grab the Asus plugin for it. Install it and you can now control all the board lighting.
    Ram is not working unless you have Corsair's ram. Hopefully, they will add more support for more peripherals as well from other companies and more boards later on.
    I really appreciate Asus listening to all our complaints and asking them to let Corsair fix their software. It can only get better from this point on out. As I always noted we need one software to control all RGB lighting. Or let it all control everything and we choose what we want to use. Baby steps are fine at this point though. We now have our foot int he door.
    Youtube announcement for it:
    https://youtu.be/D2L0Iz5jCDA
    Corsair's forum link and plugin:
    https://forum.corsair.com/v3/showthread.php?t=192965
    I posted this in another thread. I felt it deserved a front-page post so everyone could see it.
    ROG Guru: Orange Belt Array bass junkie xl PC Specs
    MotherboardAsus Rog XI Code Z-390 -Bios -1502
    Processori9-9900-Ks @ 5.3/4.9 Cache @ 1.32v
    Memory (part number)32 GB ( 8 GB x 4 ) Team Group X @ 4133 mhz cl-17-17-17-34 @ 1.45v / vccio = 1.25v/ vcssa = 1.25 v
    Graphics Card #1RTX 3080 EVGA XC3 Ultra
    Sound CardMotherboard Realtec , Driver 87.46
    MonitorAsus PG279Q , 27 inch 165 HZ , 1440p G-Sync
    Storage #1Samsung 970 evo 1 TB x 2 m.2 nvme ssd
    Storage #2Samsung 970 evo + 500 GB (OS ) m.2 nvme ssd
    CPU CoolerDeep Cool Gamermaxx 360mm v2 / Kraken G12 s36 360mm
    CaseThermaltake View 71 full Glass
    Power SupplyEvga 1000w Platnuim
    Keyboard Corsair K95 Platnuim RGB
    Mouse Corsair Night Sword RGB
    Headset Razer Kraken 7.1 chroma
    Mouse Pad Asus Sheeth Large
    Headset/Speakers Logitech Z-5500 THX 5.1
    OS Windows 10-1909 x64 Pro
    bass junkie xl's Avatar
    Oct 2017
    28
    340
    Corsair Brings iCUE lighting control to ASUS motherboards :)
    Asus mother baords that have arora sync can now be controlled with " corsair icue " no need to run arora sync and icue !
    guru 3d link how to -https://www.guru3d.com/news-story/corsair-brings-icue-lighting-control-to-asus-motherboards.html
    just installed it i have corsair k95 key board / crsair night sword mouse / asus z370 baord / arora sync fans all controlled with corsair i cue
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,759
    ***Merged thread from motherboard section***
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Oct 2017
    28
    340
    ugh i cant get them to work together now .
    any asus arora past 1.06.7 after installing fails to load .
    Jan 2011
    20
    462
    You have to have Aura Sync Or Armoury Crate to control the ram unless it is Corsair's brand. Or you can install the Ram manufacturer's software and hope it works. As I noted it doesn't control my G.Skill ram and neither does G.Skill's software.
    Quote Originally Posted by bass junkie xl View Post
    Some have reported not having to use the Aura sync at all and just using the plugin. Or just using Armoury Carte and the plugin. That is up to the user in what He/She needs on their pc to control all the stuff.
    I had the same issue and just gave up and reran my OS and it all works now. It sucks that is how I had to resolve it. But it is done and over with now. Might can try a registry cleaner like CCleaner or Revouninstaller as well. Good luck.
    New ROGer Array
    Aug 2019
    16
    still useless. i run a rog ryujin and then theres the fact i hate anything by corsair
  7. #7
    Jan 2011
    20
    462
    When it clearly states it is for AURA Motherboards only. I hope later on more stuff will be added.
    UPDATE: I actually removed the old Aura Sync version 1.07.79. Installed Armoury Crate as I like the newer cleaner look better. Plus the fact it installed Aura sync version 3.03.70. I had to stop ICUE a few times and restart it to get my board to show back up. Then I had a device not available issue with Crate. A reboot fixed it and everything is good now.
    Side Note: Sarcasm.
    How on earth do you have 10 rep for 10 posts? And every single one is only complaints about each one? This system is clearly messed up and needs to be removed.
    Quote Originally Posted by evilkabuki View Post
  8. #8
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,759
    Quote Originally Posted by KILLER_K View Post
    Side Note: How on earth do you have 10 rep for 10 posts. And every single one is only complaints about each one? This system is clearly messed up and needs to be removed.
    I believe everyone starts with reputation points.
  9. #9
    ROG Guru: Yellow Belt Array Ch3vr0n PC Specs
    Ch3vr0n PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorCore i9 9900k @ 4.7GHZ (XMP)
    Memory (part number)CMT32GX4M4Z3200C16
    Graphics Card #1Asus Strix GTX 1080 A8G
    Sound Cardon board
    MonitorASUS VG278HR & ASUS VK278Q
    Storage #1Samsung 970 Evo 1TB (Boot) & 970 EVO 2TB (Scratch)
    Storage #23X HGST 10TB, 1x HGST 4TB
    CPU CoolerScythe Mugen 5 PCGH
    CaseCooler Master Cosmos II
    Power SupplyCorsair AX860i
    Keyboard Corsair k95 RGB Platinum
    Mouse Corsair M65Pro RGB
    Headset Corsair Voide Wireless SE
    Mouse Pad Corsair MM300 + Corsair MM800 Polaris (EU)
    Headset/Speakers Logitech Z-906
    OS Windows 10 Pro x64
    Network RouterNetgear XR500
    Accessory #1 Xbox One Elite Wireless Controller
    Accessory #2 2X Corsair LL140, 4x Corsair LL120
    Accessory #3 1x Corsair LED RGB Pro expansion kit, 2x LS100 RGB kit + 450mm expansion kit
    Ch3vr0n's Avatar
    Nov 2012
    38
    237
    Read about it, tried it, LOVE IT. Works better than the default Asus RGB and now i can finally see some lighting effects that match the rest of my rig, Thanks to this it might finally be worth in adding some ARGB strips next to my corsair lighting node pro ones. Here's to hoping they add GPU support too!
  10. #10
    Jan 2011
    20
    462
    Only thing I have an issue with switching from Aura sync to Armoury Crate is. On the Aura sync, I could control the ram separately, say if I wanted Starry-night just on the ram and allow the board to stay a Static color with ICUE. That worked fine that way. But it seems Armoury Crate doesn't want to allow you to do that. I'm not sure why it will not allow you to not sync in Armourty Crate as you can in Aura Sync.
    SIDE NOTE: It was sarcasm. I was picking with him.
    Quote Originally Posted by xeromist View Post
