Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    New ROGer Array
    Sep 2019
    5
    (help me) 16x GPU with NvME on CH7
    I seem to have issues getting my 1080Ti to run at x16 , I have an NVME drive, so I'm assuming that's the "problem" , but even with 16x + 4x thats enough lanes on my 3800x to take care of that, leaving me to believe it's my settings, can someone help me please! I've tried putting my drive in both top and bottom lanes , and can't seem to figure it out
    ROG Guru: White Belt Array Baio73 PC Specs
    Baio73 PC Specs
    MotherboardAsus ROG Crosshair VIII Formula 2206
    ProcessorAMD Ryzen 3700x
    Memory (part number)4x8 G.Skill F4-4000C17D-16GTZR
    Graphics Card #1Sapphire RX 5700 XT
    MonitorLG 34GK950F
    Storage #1Samsung 980PRO nVme 512Gb
    Storage #2ADATA SX8200PNP NVMe 2Tb
    CPU CoolerCorsair H150i Pro RGB
    CaseLian Li 011D XL
    Power SupplyCorsair AX860i
    Keyboard Logitech G513
    Mouse Logitech G903 + Powerplay
    Headset G933 Artemis Spectrum
    Mouse Pad Logitech G840 XL
    Headset/Speakers Logitech G560
    OS Windows 10 64bit
    Network RouterLynksys EA6500
    Accessory #1 Corsair Commander Pro
    Accessory #2 10xCorsair QL120 RGB fan
    Jul 2014
    11
    104
    nVme drives MUST be installed in the bottom slot (the farest one from the CPU socket), otherwise the PCIex slot 1 will run @reduced speed.
    Do you have any other PCIex card?
    Baio
    CASE Lian Li 011D XL CPU AMD Ryzen 3700X COOLER Corsair H150i Pro RGB MOBO Asus ROG Crosshair VIII Formula RAM 4x8 G.Skill F4-4000C17D-16GTZR PSU Corsair AX860i VGA Sapphire RX 5700 XT DISPLAY LG 34GK950GF AUDIO Logitech G560 SDD Samsung 970PRO NVVe 512Gb - ADATA SX8200PNP NVMe 2Tb NPUT Logitech G903 + Powerplay - G513
    New ROGer Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    726
    Quote Originally Posted by Baio73 View Post
    Baio
    Sorry none of what you suggest is supported in the manual. The Top NVME slot is direct connection to CPU and is normally the best option to use. It does not effect the speed of a single x16 PCIE device. I would and do use use the top NVME slot (nearest the CPU) on CH boards in preference to the second NVME slot.
    OP Your manual shows the configuration and what you can expect. Of note OP if you have x8 Speed there is no graphics card on the market able to use this level of bandwidth. That said if you meet criteria below x16 then you should see x16 for your graphics card. Did you use HWInfo or something to check bandwidth or simply relying on the information from the BIOS ?
    There is procedure to install Windows on NVME Drive
    1 - Make sure you unplug all SATA and USB drives, the M.2 drive has to be the only drive installed.
    2 - Go into the bios, under the boot tab there is an option for CSM, make sure it is disabled.
    3 - Click on secure boot option below and make sure it is set to other OS, Not windows UEFI.
    4 - Click on key management and clear secure boot keys.
    5 - Insert a USB memory stick with a UEFI bootable iso of Windows 10 on it.
    6 - Press F10 to save, exit and reboot.
    7 - Windows will now start installing to your NVME drive as it has its own NVME driver built in, I don't think this would work with previous versions.
    8 - When the PC reboots hit F2 to go back into the BIOS, you will see under boot priority that windows boot manager now lists your NVME drive.
    9 - Click on secure boot again but now set it to Windows UEFI mode.
    10 - Click on key management and install default secure boot keys
    11 - Press F10 to save and exit and windows will finish the install.
    Once you have Windows up and running, shutdown the PC and reconnect your other SATA drives.
    Hope you find this of help.
    New ROGer Array
    Sep 2019
    5
    Quote Originally Posted by RedSector73 View Post
    im honestly more bothered by the fac tthat i cant seem to even get a x16 option, i know x8 and 16 have like no difference, its more so just knowing that its not working that's bothering me. my nvme drive is installed in the bottom slot ( top slot forces GPU into x4 ) , no other pcie devices and im still stuck at x8. Also i dont see how that process would give me back my cpu lanes :P , i more or less do that while installing windows but no CSM or secure boot, but otherwise the same process, I don't have any issues with my m.2 drive , and I check through bios and GPU , both report x8
    New ROGer Array
    Sep 2019
    5
    Baio
    no other pcie devices, and NvME is in bottom slot top slot gives me x4 , bottom gives me x8 at best
    Baio73 PC Specs
    MonitorLG 34GK950F
    CaseLian Li 011D XL
    OS Windows 10 64bit
    Jul 2014
    11
    104
    The images you posted from the manual show Asus called M.2_1 the bottom slot and M.2_2 the upper one (the nearest to the CPU).
    According to the manual, the bottom slot is the only that can allow for sure 16x to VGA and 4x (if needed) to nVme drives, as they wrote for M.2_2 "Support" and not "4x". Don't know exactly what it means, but I'm quite sure… maybe some one directly from Asus can confirm.
    Baio
  7. #7
    Baio73 PC Specs
    MonitorLG 34GK950F
    CaseLian Li 011D XL
    OS Windows 10 64bit
    Jul 2014
    11
    104
    Quote Originally Posted by EhRabzz View Post
    What software are you using to state that?
    Try with GPU-Z.
    Baio
  8. #8
    May 2013
    93
    Baio
    What this guy said is correct and I have the C7H with a 2080 and a 2TB NVME.
    It does state in the manual that if you place the M.2 in the slot closes to the CPU that it shares its lanes with the top PCIex slot. So if you put an M.2 in that slot it will then downgrade the speed of the graphics card in the top most slot from x16 to x8.
    The only way to get full speed is to place the M.2 into the furthest most slot from the CPU and then you will get your x4 speed for the M.2 and your x16 for the graphics card.
    It is in the manual, I highly recommend you follow that as there is absolutely no other way to get it to work.
  9. #9
    Apr 2018
    40
    726
    I was wrong, my bad. You should use the bottom one, disregard what I said about using the top, it is incorrect.
  10. #10
    Baio73 PC Specs
    MonitorLG 34GK950F
    CaseLian Li 011D XL
    OS Windows 10 64bit
    Jul 2014
    11
    104
    Quote Originally Posted by Lothos View Post
    What is indicated in the manual ("Support") for M.2_2 slot probably means the nVme will simply work but no speed is guaranteed.
    Baio
Tags for this Thread
