GL 504GS fans + ventilation problems?
Boberto
Recently I had new thermal paste applied and I've noticed my laptop being noticeably louder even on silent mode. I've opened up the backconsole and can confirm both fans are spinning and clean but I am only getting ventilation out the right vent and the back right vent, nothing from the left vent. I'm not sure if this is intended or not, but I'd appreciate some clarifcation if anyone can provide some.
TX2000
check your connectors to see if you dont have a bent pin. also right vent? when you are looking the computer from what orientation?
