Results 1 to 1 of 1
01-09-2020 11:57 AM #1
Nicholas Steel PC Specs Motherboard ASUS Crosshair Hero VIII WiFi Processor AMD Ryzen 3700X Memory (part number) 16GB DDR4 3600Mhz Graphics Card #1 Nvidia Geforce 1070Ti 8GB Sound Card Integrated Monitor Samsung P2350 CPU Cooler Noctua NH D-14 Case Fractal Design Define R5 Power Supply Corsair AX760 Keyboard DELL SK8110/Logitech Orion 610 Mouse ASUS Gladius Headset Sennheiser HD380 Pro OS Windows 10 Pro x64
- Join Date
- Mar 2014
- Reputation
- 10
- Posts
- 23
Crosshair Hero VIII WiFi - Only one USB 3 Front Panel Port works?
My Fractal Design Define 5 case has two USB 2 and two USB 3 ports on the front of the case and after plugging everything in it seems like only one of the USB 3 ports is working (the right most port). The port to its left doesn't recognize nor charge any device plugged in to it.
https://www.pccasegear.com/products/...id-tower-black
Pretty sure the case only has a single USB 3.0 plug for the motherboard, so... yeah it seems weird right? Unless the port in the case is faulty or developed a fault I guess (I've had the case for a while now with a motherboard that lacked the ability to use those ports)Computer specifications:
Windows 10 Pro x64|AMD Ryzen 3700X|ASUS Crosshair Hero VIII WiFi Motherboard|16GB DDR4 3600Mhz RAM|Integrated Audio|MSI Geforce 1070Ti|Corsair AX760 Platinum Power Supply|Fractal Define Design R5 Computer Case|Samsung P2350 Monitor
