Results 1 to 7 of 7
01-11-2020 10:51 PM #1
Unable to Bypass Battery Warning While Updating BIOS ROG G751JT - solved
Hello all!
I have a 4+ year old veteran here, however the laptop still has above average performance, although it's a 2014 model:
ASUS ROG G751JT
Intel Core i7-4720HQ
16 GB RAM
NVIDIA GeForce GTX 970m
120 GB SATA SSD
1 TB HDD
I have made a research on compatibility with NVME SSDs, and I have opened my laptop to confirm that I have the required PCIe slot (from what I know some G751s do not come with PCIe), and I do!
So far so good, however I have never flashed the BIOS, so it's currently with the version the laptop was shipped with - 210. To support NVME SSD, the BIOS needs to be updated to 211 and above.
I have tried to upgrade it with WinFlash, downloaded from ASUS (tried both 211 and latest 213) and through the embedded in the BIOS EasyFlash with no luck. As my battery is dead (0% not erroring, not charging) the update wouldn't go through.
According to my research, once I see the blue screen alert, advising the update would not continue due to the battery level being below 20%, I need to type "risky" using my keyboard. I saw videos of it working, on all sorts of ASUS laptops (ROG and non-gaming), however there's no reaction in my case whatsoever.
I have tried to reset the BIOS to default settings, multiple restarts, etc., however the situation remains the same. As instructed I put the BIOS files in a FAT32 formatted flashdrive.
Would anyone know another way to bypass the error?
I hope I provided all details needed.
If you're reading this - thank you for getting to the bottom to this awfully long thread, concerning just a stupid battery error. Any input is greatly appreciated!!!Last edited by dyduty; 01-11-2020 at 10:53 PM.
02-05-2020 01:17 PM #2
Resolved
I was able to flash the BIOS of my G751JT by simply disconnecting the battery without removing it. The warning seems to be not applicable for missing batteries.
06-09-2020 10:13 PM #3
GianDelR PC Specs Laptop (Model) ROG G751JT Motherboard G751JT
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 8
06-29-2020 07:52 AM #4
- Join Date
- Nov 2015
- Reputation
- 10
- Posts
- 6
i need help with this as well :/
07-20-2020 07:41 AM #5
- Join Date
- Feb 2019
- Reputation
- 13
- Posts
- 539
Hello GianDelR & Jin1337,
May I know which model do you have and what kind of issue did you encountered?
Your battery are dead and can not be charged anymore?
10-15-2020 05:09 PM #6
- Join Date
- Aug 2015
- Reputation
- 10
- Posts
- 1
Hello,
I have the same problem as well. I cant flash my BIOS due to the dead battery(can't be charged), I have tried the Easy Flash method and type "risky" and it doesn't work on me, I have the same model (Asus ROG G751JT).
Thanks,
AlainLast edited by alain1022; 10-15-2020 at 05:14 PM.
10-22-2020 09:59 AM #7
- Join Date
- Feb 2019
- Reputation
- 13
- Posts
- 539
