Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    New ROGer Array louis925 PC Specs
    louis925 PC Specs
    MotherboardASUS ROG Strix X570-E Gaming
    ProcessorAMD Ryzen 9 3900X
    Memory (part number)G.Skill F4-3600C16D-32GTZNC
    Graphics Card #1ASUS ROG STRIX RTX2080TI O11G GAMING
    MonitorASUS VE276Q
    CaseNZXT H710
    Dec 2019
    21
    How to turn off RAM RGB when system is in sleep?
    I just got my ASUS ROG Strix X570-E motherboard with G.Skill RGB memory. I was able to control the RGB on the RAM using Armoury Crate and on my motherboard I set to turn off all LED when system is in sleep. However, the G.Skill RAM doesn't seem to turn off RGB when in sleep. I was wondering if there is a way to do that?
    LED light is super bright in night in my room so being able to control the LED RGB is a crucial functionality of a motherboard.
    Thanks!
    ROG Guru: White Belt Array
    Jul 2013
    97
    Try to change the System Sleeping States in the bios.
    BIOS ---- "Advanced" ---- "APM Configuration" ----- "ErP Ready" ----- to "S4+s5"
    On my z370 board, the LEDs were even active when the pc was turned off
    System Sleeping States description
    Link https://docs.microsoft.com/en-us/win...ectedfrom=MSDN
    New ROGer Array Braegnok PC Specs
    Braegnok PC Specs
    MotherboardAsus Maximus XI Apex
    ProcessorIntel Core i9-9900KS
    Memory (part number)CMK16GX4M2K4600C19
    Graphics Card #1Nvidia RTX2080TI FE
    Graphics Card #2Nvidia RTX2080TI FE
    MonitorPredator X27
    Storage #1Samsung 970 Pro
    CPU CoolerKoolance EXC-800
    CaseTT A700 TG
    Power SupplyCorsair AX1600i
    Keyboard Das 4 Ultimate
    Mouse Logitech G Pro
    Headset SteelSeries Arctis Pro
    OS Windows 10 Pro 64-Bit
    Braegnok's Avatar
    Nov 2019
    35
    Quote Originally Posted by louis925 View Post
    Thanks!
    Try going into BIOS, Advanced, Onboard Devices Configuration, LED Lighting, and then select [Stealth Mode] from drop down menu. https://imgur.com/a/xm3DitO
    louis925 PC Specs
    MonitorASUS VE276Q
    CaseNZXT H710
    Dec 2019
    21
    To Tom Tromboni:
    Thanks! Enable ErP to S4+S5 does turn off the two white led lights on my graphics card when the system is power off!!
    Though when the system is in sleep the two white leds and the RAM rgb lights remain on.
    To PMBraegnok:
    I did select the [Stealth Mode] already in BIOS when the system is in sleep. But it still have RAM rgb and graphics card white leds on when in sleep.
    Jul 2013
    97
    I don't have G.Skill RAM, but try the software from G.Skill Trident Z Family
    https://www.gskill.com/download/1502...B,-Royal,-Neo)
    Maybe it fixes the problem
    Best regards TOM
    louis925 PC Specs
    MonitorASUS VE276Q
    CaseNZXT H710
    Dec 2019
    21
    In their installation note, they said "This software may conflict with other LED lighting control software (such as ASUS Aura, Gigabyte RGB Fusion, MSI Command Center/Mystic Light, NZXT CAM, etc.). Please do not install multiple software at the same time, or the software may not work as intended. We are working to improve compatibility between the different software programs."
    Hmm... After I installed G.Skill Trident Z Lighting Control, my ASUS Armoury Crate can't see any RGB devices.... And the LightingService can not start. Guess, I will remove it then...
  7. #7
    Jul 2013
    97
    It's a pity it's not compatible.
    *It would be so easy if the programming of the Software was coordinated
  8. #8
    Braegnok PC Specs
    MonitorPredator X27
    CaseTT A700 TG
    Braegnok's Avatar
    Nov 2019
    35
    When I first set-up my PC, I had Asus Armoury Crate software pre-installed when I installed Windows 10, and with Corsair H150i cooler I had to install Corsair Link-4 software, I was running G.SKILL 3600C14 Z Royal memory so I installed G.SKILL Z Royal Lighting Control software.
    It was a nightmare light show, all LEDs flashing, rainbow colors and no control. I spent days trying to control all the LEDs with no luck.
    Only software I could control memory LEDs with was Corsair Link 4, and could only change from flashing rainbow to static red, which drove me crazy for days.
    Then I decided to just shut off all LEDs. I set all LED jumpers on motherboard to Disable, I uninstalled G.SKILL Software,.. and using Corsair Link 4 was able to choose static black on color choice and got a vary light silver color on water block but memory would still only go static red, and would not disable.
    Becoming more frustrated, noticing Armoury Crate was causing issues with my NvLink SLI and that was the last straw.
    I pulled the G.SKILL Z Royal memory, replaced it with Corsair LPX modules, did a clean Windows 10 install, I did not re-install Armoury Crate,.. left all LED jumpers in disable,.. and now life is good!
  9. #9
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    960
    Have you considered a hard power down to resolve? A hard power down with ERP enabled should kill the light.
  10. #10
    louis925 PC Specs
    MonitorASUS VE276Q
    CaseNZXT H710
    Dec 2019
    21
    Quote Originally Posted by mdzcpa View Post
    Yes, ErP enabled with power off does kill all the light, but that also means I will have to restart all the programs next time I boot my PC, which can impact my productivity. That is why I only prefer to use sleep for my computers. Right now my work around is to manually switch to night mode in Armoury Crate before sleep...
