Results 1 to 9 of 9
    ROG Guru: Orange Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME
    ProcessorIntel Core i9 7980XE 2.6GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG UD590D
    Storage #1INTEL600P 1TB
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 10 2021 Insider Preview 19592.1001
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    41
    487
    Lightbulb Say goodbye for Intel Turbo Boost MAX 3.0 Driver due EOL with SA-00243
    A potential security vulnerability in the Intel® Turbo Boost Max Technology 3.0 driver may allow escalation of privilege.
    Intel is not releasing updates to mitigate this potential vulnerability and has issued a Product Discontinuation notice
    for the Intel® Turbo Boost Max Technology 3.0 driver.
    Intel has issued a Product Discontinuation notice for the Intel® Turbo Boost Max Technology 3.0 driver and
    recommends that users of the Intel® Turbo Boost Max Technology 3.0 driver uninstall it or discontinue use
    at their earliest convenience. This does not affect Intel® Turbo Boost Max Technology 3.0 functionality when
    used with in operating systems with native support (Windows 10 RS5 and later).
    https://www.intel.com/content/www/us...-sa-00243.html
    Core i9 7980XE / R6E 3006 MODDED / Intel 02006901 MCU 2020-02-12 / VROC VMD 6.3.0.1005 / RST 17.8.3.4687 / ME FW 11.12.77.1664 DV 1952.14.0.1470 / 64GB GSKILL @3.2GHz 16-18-18-38 2T / POSEIDON 1080i GTX + NVIDIA Driver 450.99 WHQL / AX1200i / 1TB NVME 600P + OMS Driver 17.8.8.1072 WHQL / Microsoft Windows 10 Version 2004 Build 19631.1000 / i219 V PHY UNDI OROM / Boot Agent 0.0.29 / 0.1.16 / 12.18.9.23 WHQL WHQL AQC 107n FW 3.1.109 + AQC 2.1.21.0 WHQL. CAM 4.7.0 Realtek HD 6.0.8934.1 WHQL
    New ROGer Array H-de PC Specs
    H-de PC Specs
    MotherboardWS-X299-PRO
    ProcessorIntel Core i9-10900X
    Memory (part number)KHX3200C16D4/4GX
    Graphics Card #1EVGA RTX 2080 XC Ultra Gaming
    Sound CardHyperX(USB)
    CPU CoolerNoctua NH-U9S
    CaseFractal Design Define R6 White
    Power SupplyCooler Master v750
    Keyboard HyperX FPS Blue-Switches
    Mouse Zowie FK1
    Headset HyperX Cloud 2
    Mouse Pad QCK+
    OS WIndows 10 Build 2004
    H-de's Avatar
    Aug 2018
    11
    30
    I always used native TB3
    not sure why ASUS have OS Support as Default setting for TB3
    Other mainboard manufacturers like GIGABYTE have TB3 native as Default
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS x99 sabertooth 2nd x299 Rampage VI Apex
    Processori7-5930k & i9-9940x
    Memory (part number)Trident-Z 3200C14 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Coolerx99 2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Heatkiller 4 Pro copper plexi/Optimus Foundation copper plexi
    Accessory #2 Mayhems Biocide and Inhibitor with distilled water
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro
    ThrashZone's Avatar
    Oct 2017
    23
    378
    Bloat/ crapware always disable anyway and kill it in task manager so it never starts again and a little cmd magic
    Good riddance !!!
    Jpmboy
    remove INtel Turbo Boost 3.0...
    Here's a proper way to disable the application (with device driver intact).
    1. RIght-click on the tray icon, and disable it.
    2. Open Task Scheduler and disable Intel Turbo Boost Max Technology 3.0
    3. Open Command Prompt and type “sc config ITBMService start= disabled”
    4. Reboot.
    Now back into bios and disable EIST (Enhanced Intel SpeedStep), and Enable SpeedSHIFT.
    F10 to save and reboot.
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Sep 2017
    41
    487
    Quote Originally Posted by ThrashZone View Post
    Good riddance !!!
    Jpmboy
    Thank you ThrashZone
    H-de PC Specs
    Mouse Zowie FK1
    Mouse Pad QCK+
    H-de's Avatar
    Aug 2018
    11
    30
    Start CMD as admin and enter
    C:\Windows\system32>sc delete ITBMService
    ROG Guru: White Belt Array EaglePC PC Specs
    EaglePC PC Specs
    MotherboardASUS ROG STRIX X299-E GAMING
    ProcessorI9-7900X
    Memory (part number)CMW32GX4M4C3000C15
    Graphics Card #1EVGA GeForce GTX 1080 Ti FTW3 GAMING
    MonitorASUS ROG Swift PG348Q
    Storage #1SAMSUNG 970 PRO 512GB
    Storage #2SAMSUNG 860 EVO 500GB
    CPU CoolerCORSAIR H115i PRO
    May 2014
    28
    123
    guess this explains it to my post https://rog.asus.com/forum/showthrea...ted#post798848
    Asus Rampage VI Extreme / Intel I9-7940X / Corsair H115i Pro / CORSAIR Vengeance RGB Pro 32GB (4 x 8GB) 3000MHz / EVGA GeForce GTX 1080 Ti FTW3 ELITE GAMING BLACK Edition / 2x Samsung 970 Pro NMVe 1GB / 4x Samsung 850 PRO - 2TB / Asus ROG Swift PG348Q / Corsair AX 1500i / Thermaltake View 71 RGB PC Case /Win 10 PRO x64
  7. #7
    Feb 2019
    67
    260
    Funny how they made a huge PITA to get rid of for the longest time.
    Uninstall and it would come right back. Now its as simple as an uninstall.
  8. #8
    ROG Member Array
    Apr 2018
    5
    This thing keeps getting installed every time I restart. But at least it is disabled now. Any idea to how to get rid of this thing completely?
    I did every step above.
  9. #9
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Sep 2017
    41
    487
    Depending on your Windows 10 version. If you use version 2004 and above it was disable by default.
    Older version must be uninstalling by manual.*
