Results 1 to 4 of 4
    New ROGer Array skottie PC Specs
    skottie PC Specs
    Laptop (Model)GL703GE
    MotherboardASUSTeK COMPUTER INC. GL703GE (U3E1)
    ProcessorIntel Core i7-8750H @ 2.20GHz Coffee Lake 14nm
    Graphics Card #1Intel UHD Graphics 630
    Graphics Card #2NVIDIA GeForce GTX 1050 Ti
    Sound CardIntel Display Audio Realtek High Definition Audio
    Storage #1Seagate ST2000LX001-1RG174
    Storage #2KINGSTON RBUSNS8154P3128GJ
    Keyboard HID Keyboard Device
    Mouse HID-compliant mouse
    OS Windows 10 Home 64-bit
    Network RouterD-Link 882 AC2600 MU-MIMO
    Accessory #1 Intel Wireless-AC 9560 160MHz
    Apr 2019
    1
    Tips/Suggestions on Cleaning Screen Display?
    My screen is dirty as hell and just poking my head in to see if anyone has any preferred methods for cleaning your display screen.
    Thanks!
    New ROGer Array
    Jan 2020
    26
    Quote Originally Posted by skottie View Post
    Thanks!
    For me:
    Step 1: Use a soft vacuum brush and suck it off. (I found this vacuum brush that was made of soft camel hair).
    Step 2 If it's more than dust: I use a microfiber cloth that is clean (no previous gunk) and water. Spray the water on the cloth and wipe gently. I've also misted the screen and then wiped. Never use tissue, paper towel or an old shirt.
    Step 3 If it's still dirty from grease or whatever: I've used a 30% solution of water and rubbing alcohol (that would be Isopropyl alcohol), and do the same as #2.
    Some people warn you not to use alcohol, but I've never had a problem. I think the concern was you might melt the case or screen. I suppose you could test. Probably always better to mist the cloth and wipe if you use the mix. Usually the water does the trick. BTW, if you have hard water with a lot of minerals, you might want to try distilled water.
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71
    MotherboardROG Maximus IX Extreme
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 2004
    Network RouterGeneric
    Accessory #1 ROG Aura Terminal
    Accessory #2 ROG 10GB Express
    Accessory #3 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Jan 2016
    214
    I wipe with a clean damp microfiber cloth immediately followed by a wipe down with a clean dry microfiber cloth. The smashed spider between the panel and light source is still there. Yep, the Amazing Spider Pixel shows on all colors except black.
    ROG Guru: Yellow Belt Array Carlyle2020 PC Specs
    Laptop (Model)amd4000 for sure next time
    MotherboardAsus Maximus XI APEX
    Processorgaming9900ks/@5.2 avx -1 / manual vcore 1.32/LLC5/AC+dc 0.01/TVB off/all power savings on
    Memory (part number)Corsair LPX 4000 CL19@16.17.28/300/2T/ 1.42 volt
    Graphics Card #13080
    Sound CardXonar STXII mods:3xLME 49720NA
    MonitorLG 38GL950G / -HDR / +madVR
    Storage #12TB 970evo plus nvme
    Storage #21TB 960evo nvme +2x 1tb evo 860 hw-sata-raid
    CPU Coolerarctic freezer II 280
    CaseV2-Silverstone FT2 dampened up the wazoo
    Power SupplySeasonic TX-850
    Keyboard Cherry KC 1000 on top of a cherry MX1 for ergonomics :)
    Mouse MX Master 3
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers A250 / cause LG was stingy
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off
    Accessory #3 4 bay fantec /10tb red/+scrap
    Mar 2018
    17
    144
    Thanks!
    That includes sticky, grimy, tried up, caked, crystalized and condensated ickyness with small and big scratchy things held hostage in it and on it.
    ...a dry cloth and water ain't cutting it here I presume?
    Buy LCD/Monitor spray (always read the label) and paper towels.
    Wet 3 unfolded paper towels until they drip of fluid and wet wipe the screen once with a lot of ease and care only to get the loose and big stuff off.
    Have dry ones in the other hand for fluids dripping down the screen.
    …Did I mention A LOT of ease and care? Oh well:
    Then get new paper towels wet and get to test work on the upper right corner and try swirling motions at first until you have removed any dirty film, always keeping the surface a little wet.
    Use soft pressure, changing the spot on the towel more times than u think u should until you have one small 100% clean corner.
    If that works invade the rest of the screen from that clean spot, always swirling through the clean spot to and over the dirty film.
    After expelling the dirty film on there you can slowly move to a dry cloth or paper towel.
    By that time there should not be anything on there that the dry paper towel could scratch into your screen.
    …Hulks may have to be excluded from this I suppose.
    Good Luck and don’t sue me please!
