Maximus X issue with Bluetooth+USB device
jshekhel
Folks,
I have an Xbox wireless controller with the USB charging kit. Everything works fine until I plug in the controller to charge via USB. After that the controller can no longer connect via Bluetooth. I need to remove the device from the Bluetooth list and pair it again.
Am I doing something wrong, or is this a common problem?
Thanks!
jshekhel
Folks,
I've discovered that this problem remains even if I charge the controller on a different PC, so I no longer believe this is an ASUS motherboard Bluetooth issue. The controller itself seems to lose its Bluetooth pairing information when plugged into a PC via USB.
My solution for now is to charge the controller directly from a USB wall plug adapter. That seems to work.
Thanks!
