Results 1 to 5 of 5
    ROG Enthusiast Array Konig PC Specs
    Konig PC Specs
    MotherboardROG Rampage VI Extreme OMEGA
    ProcessorSkylake X Intel Core i9-7980XE
    Memory (part number)G.Skill 64GB (8x8 GB) Trident Z RGB DDR4 3200MHz
    Graphics Card #1NVIDIA TITAN RTX
    Graphics Card #2NVIDIA TITAN RTX
    Sound CardSTRIX Raid DLX
    MonitorBenQ PD3220U 32 inch 4K UHD IPS
    Storage #1Intel 280GB Optane SSD 900P 2.5 U.2
    Storage #2Samsung 512GB 960 PRO SSD M.2 and Samsung 4TB 860 EVO SSD 2.5
    CPU CoolerCustom liquid cooling for CPU and GPU
    CasePhanteks Enthoo Elite
    Power SupplyCorsair 1600W AX1600i
    Keyboard ASUS ROG Claymore
    Mouse ASUS ROG Gladius II
    Headset Sennheiser GSP 600 Headset
    Mouse Pad ASUS ROG Sheath XXL
    OS Windows 10 Pro 64-bit
    Network RouterASUS ROG Rapture Gaming Router AX11000
    Accessory #1 NVIDIA TITAN RTX NVLink Bridge 4-Slot
    Accessory #2 Thermal Grizzly Conductonaut Liquid Metal CPU
    Accessory #3 Thermal Grizzly Kryonaut Thermal Paste
    Feb 2016
    28
    70
    Question Rampage Vi Extreme Omega PCIE Lanes
    Hi everyone,
    I have a 44 Lane CPU and two Titan RTX in SLI on my motherboard that would be 32 PCIE lanes used and I also got a Intel 900p U.2 which would make it a total of 36 PCIE lanes consumed and I was wondering where I need to place my M.2 drives so everything runs at maximum speed and from the CPU.
    There is two M.2 slots on the board and another 2 on the Dimm.2 slot but according to the manual M.2_2 shares the bandwidth with the U.2 slot and M.2_1 runs from the PCH ? and shares bandwidth with PCIE 3.0 x4 according to some reviews online, that means Dimm.2 is my only option but where does Dimm.2 get lanes from ? apparently you cant run U.2 and Dimm.2 at the same time.
    I also have a question about PCIE 3.0 x4 slot and I was wondering how im supposed to put my sound card inside this slot since my bottom Titan blocks the slot since the IO is 2 slot while the card itself is 1 slot now with the waterblock, can I cut the plate and remove the bottom display port ? or would that cause the card to stop working ? I really want to use that PCIE 3.0 x4 slot and I cant figure out how to mount it, I did try the last PCIE 3.0 x16 slot and it turns the GPUs into 8x 8x mode instead of 16x 16x and this reduce my performance a lot. I have only seen 16x Riser cards and maybe I can cut this into 4x ? or would that cause signal to worsen ?
    Last resort I see is to buy that new Rampage Vi Extreme Encore motherboard since that one have the PCIE 3.0 X4 slot in between the two GPUs so that would work but ditching out 1000 dollars for a brand new motherboard with minimal upgrades over the omega and also losing the U.2 really would suck
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    389
    Dimm-2 would likely be pch not pci-e
    Bios might have a way to switch modes
    U.2 is likely going to drop sata ports rather than pci-e lanes.
    ROG Enthusiast Array Aysberg PC Specs
    Aysberg PC Specs
    MotherboardASUS ROG RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9-7980XE
    Memory (part number)4 x F4-3200C14-16GTZ
    Graphics Card #1EVGA RTX 2080 Ti XC Ultra Gaming (11G-P4-2382)
    Graphics Card #2EVGA RTX 2080 Ti XC Gaming (11G-P4-2382)
    Monitor1x LG 34GK950G / 2 x HP DreamColor Z27x
    Storage #12 x Samsung NVMe 970 EVO 2TB / Samsung NVMe 3 x 960 EVO 1TB
    Storage #24 x SanDisk SDSSDHII960G
    CPU Coolercuplex kryos NEXT
    CaseLianLi PC-A75X
    Power SupplyCorsair HX1200i
    Keyboard Corsair K95 RGB
    Mouse Roccat LEADR
    Headset AKG K712 + ModMic 5
    OS Windows 10 Pro x64 1909
    Network RouterMikroTik CRS317-1G-16S+RM
    Accessory #1 Mellanox ConnectX-3
    Accessory #2 Asus Hyper M.2 X16 Card
    Nov 2013
    18
    69
    When I got the board I tried to find the lane allocations via HWInfo, you can find my result here.
    For the M.2 ports it looks like this...
    M.2 Slots (12 CPU lanes in total / 4 via PCH)
    M2_1 Onboard (between PCIEX16_2 and PCIEX16_3) -> PCI Express 3.0 4x via PCH
    M2_2 Onboard (between PCIEX16_1 and PCIEX16_2) -> PCI Express 3.0 4x via CPU
    DIMM.2_1 Module -> PCI Express 3.0 4x via CPU
    DIMM.2_2 Module -> PCI Express 3.0 4x via CPU
    Have no U.2 to check how those are connected, but according to the manual it shares the lanes with M.2_2 connected to the CPU.
    PS Before you cut your Titan RTX, give it to me. I could use this beast for GPU rendering There are PCIe 4x riser cables on the market! So I would go this way or use another sound card (USB or just onboard).
    Konig PC Specs
    Feb 2016
    28
    70
    Thanks a lot for the info, I guess I’m safe then with two Titan RTX, intel 900p U.2 and two 970 Evo plus on Dimm.2 that would be total of 44 Pcie.
    Since M.2_1 goes to PCH will that turn of the PCIE 4x slot ? If that M.2 slot is used or would it just be running lower bandwidth since I will have a sound card there ? Since I believe M.2_1 is routed to PCIE x4 that runs from the PCH.
    Indeed I also did see that there is 4x PCIE riser cables just very ugly looking ones :/ guess that’s better than cutting into a 3000$ card lol x2 also.
    Aysberg PC Specs
    CaseLianLi PC-A75X
    Mouse Roccat LEADR
    Nov 2013
    18
    69
    Everything connected to the PCH will be able to run at the same time, but shares the DMI 3.0 connection to the CPU (which equals PCIe 4x speeds, as far as I know). Your sound card wont use much bandwidth, so I wouldn't expect any noticeable impact on the NVMe performance, at least not in real life, maybe in benchmarks.
