Results 1 to 3 of 3
    New ROGer Array
    Jun 2019
    2
    Lightbulb Can i use G501VW battery for G501JW ?
    Hello
    My g501jw battery expanded and i want to change it but there are different part numbers for battery
    I don't want to remove my hard drive for using 6 cell battery.
    so i found these two part number:
    C41N1416 4cell battery 60Wh and about 3700 mAh (this is my currently using battery)
    C41N1524 4cell battery 60Wh and about 4600 mAh (this is for G501VW)
    My question is Can i use g501vw battery for my laptop (JW) ? because the second one has more capacity and longer battery life
    I found these pictures for inside of both laptops: (first one is G501JW and second one is G501VW)
    I think i can't use G501VW battery because there is a screw place on bottom of the pictures that is differ with each other ( marked blue line )
    What is your opinion ?
    ROG Guru: Green Belt Array
    Nov 2012
    67
    702
    It appears both batteries can be used in either laptop.
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    New ROGer Array
    Jun 2019
    2
    Quote Originally Posted by jdfrench3 View Post
    Everything looks like the same but the screw place that i mentioned is not placed at the same location
    and the reason of my doubt is that
