Results 1 to 2 of 2
02-05-2020 10:50 AM #1
- Join Date
- Jan 2020
- Reputation
- 10
- Posts
- 4
Asus Maximus vii Hero and i7-4790k Over-Heating Issue.(Doubt)
For a long time(Years) my computer fan used to scream like a banshee whenever I worked in video editing or I turned my OBS recording on. It was only recently I realized that my CPU is overheating a lot constantly. The temperature went to 80C+ on Loads and 100C+ when I run a stress test (It was 40C on min). I'm using a software called core-temp to check the temp.
Yesterday I came across this thread on Asus ROG Forum and tweaked those 3 settings in the Bios my CPU fans have not screaming at me. I get <70C at 100%load (Stress test) and min is 35C. I just want to double-check if everything is alright now or did I end up messing something...(Why did changing this settings from "auto"->the optimized value fix my overheating issues? I assumed my motherboard will automatically put the best settings) I have not overclocked my CPU.
The Forum Image which showed me what values I should set.
My Current State(After optimization) shown in Cpu-Z
02-05-2020 08:13 PM #2
xeromist PC Specs Laptop (Model) Dell Inspiron 15 7567 Motherboard MSI x470 Gaming Plus Processor AMD 2600X Memory (part number) 16GB Crucial Ballistix Elite 3600 Graphics Card #1 ASUS GTX 1080 Strix Monitor BenQ BL3200PT Storage #1 Intel 600p NVMe CPU Cooler Wraith Case custom Antec 900 Power Supply Corsair HX1000 Keyboard Logitech Orion Spark Mouse Logitech MX500 Headset Plantronics 777 with Oregon Aero upgrade
- Join Date
- Jul 2010
- Reputation
- 318
- Posts
- 7,754
Often motherboard manufacturers will use default voltages that are higher than strictly necessary in order to ensure stability. More voltage also means more heat. A low quality CPU may become unstable with lower voltages where a golden sample may be able to undervolt significantly while remaining stable. Because the board cannot know how good your CPU is it may use a higher voltage guaranteed to work with the largest number of CPUs.
Also, occasionally there will be bugs. Sometimes a newer or older BIOS may work better.* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
