Results 1 to 3 of 3
    New ROGer Array
    Jan 2020
    8
    ASUS ROG Strix X570-E Gaming and power of internal USB 3
    hello,
    I am surprise to see the power of internal usb 3 ASUS ROG Strix X570-E Gaming, connected to my tower bequiet silentbase 600 on USB 3 port between 300-400mA (power give by my apps phone). It's like USB-2. USB 3 seems working at good speed.
    If i plug on another desktop on usb 3, i am between 600-700mA.
    What does it means ?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,586
    Make sure to compare plugging in directly to the back of the motherboard to eliminate the case wiring as a factor.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Jan 2020
    8
    Quote Originally Posted by xeromist View Post
    Be quiet support said me it is the motherboard.
    And i haven't any cable to pluggin directly (because it is pin connector).
