Results 1 to 5 of 5
    ROG Member Array
    Feb 2013
    21
    G75VX-T4153H - max SSD upgrade size?
    I'd like to upgrade my aging laptop.
    I've selected another 2x8GB SODIMMs and a replacement battery.
    I'd like to replace the 256GB SSD and 1TB HDD with 2 x 1TB SSD.
    Before I make the purchase I wanted to be sure the BIOS would be OK with this.
    BTW, I'd happily upgrade the 670MX if that was a viable possibility.
    Cheers in advance for the help.
    Mech.
    Last edited by TheMechWarrior; 02-08-2020 at 04:26 AM. Reason: Spelling error in the title
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,622
    ***Moved to sub-forum where people who may have tried this can read it***
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Green Belt Array
    Nov 2012
    67
    699
    Yes, the G75 BIOS are prone to fail when swapping drives. Can't do anything about that.
    1. Use Macrium Reflect software (Free Version) to copy your drives.
    2. Remove your secondary drive throughout procedures.
    3. Use a USB to SATA cable to attach your new drives while copying your drives. Don't use the built-in secondary SATA connector. Possible link to BIOS failure.
    4. First, copy your 256GBSSD to your new 1TBSSD attached to the USB to SATA connector. Then replace the 256GBSSD with the new 1TBSSD.
    5. Reboot your laptop (secondary drive still not in place) several times, make sure everything looks good.
    6. Now install your old secondary 1TBHD and reboot the laptop and insure things still are good.
    7. Using Macrium Reflect software, copy your secondary 1TBHD to your new secondary 1TBSSD attached to the USB to SATA connector.
    8. Swap your secondary drives, reboot, make sure everything is great.
    Here's a link for USB to SATA cable:
    https://www.newegg.com/p/181-00D8-00...+to+sata+cable
    Now for a different solution:
    Here's a link for a Hard Drive Duplicator/SSD Cloner:
    https://www.newegg.com/wavlink-wl-st...0VN-0069-00014
    With this device you can clone your drives without need of any other software. I have one of these and have used it many times. Offline clone capable.
    1. Remove both old drives from laptop.
    2. Plug-n the Duplicator to power.
    3. Insert old 256GBSSD and new replacement 1TBSSD and clone. Remove drives.
    4. Insert old 1TBHD and new replacement 1TBSSD and clone. Removes drives.
    5. Install the new drives in the laptop. Reboot. Make sure everything is working correctly.
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,135
    Your 2x8Gb Sodimms must match the current installed RAM Timings and Voltages exactly
    Upgrading your hard drives to SSD should be no issues I would suggest Samsung 860 Evo's up to 4 TB each if you like. 2 TB if your system is 32 bit
    I use Macrium Reflect also great program Zero failues since 2012 When I first found it.
    Not sure about the GPU upgrade, you might PM Dreamonic with that question
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Member Array
    Feb 2013
    21
    WOW!
    This is everything I asked for AND more!
    I hadn't considered the timings of the ram.
    I'll buy 4 of the same 8GB modules, also I had no idea I could upgrade as far as 4TB for the SSD.
    Thank-you both and a special thanks to @jdfrench3 detailed "how to guide".
    Cheers,
    Mech.
Tags for this Thread
