Asus b365-f Motherboard - RGB settings in the BIOS not savedd, Audio problems
aeioux
Firstly I've been repeatedly DISABLING the following option in the BIOS;
Advanced > Onboard Devices Config > RGB LED Lighting
"When system is in sleep, hibernate or soft off states"
The BIOS is simply not remembering this setting, and defaulting back to ENABLED on every reboot/power off which means the RGB effect is showing on the shroud all the damn time.
Secondly, I had to give up using the onboard Audio as after 15-20 minutes of music playback, strange glitches and playback errors would occur - using Winamp or other MP3 players had the same result. All drivers updated. I have now had to buy external USB soundcards to resolve this.
Not very impressed with this Motherboard to be honest.
Any tips - particularly for the BIOS problem - gratefully received.
Thanks,
Chris
aeioux
Separately from the RGB BIOS settings "When system is in sleep, hibernate or soft off states" that were being ignored, I found this in Armoury Crate:
Armoury Crate > DEVICE > (Select your device) > Shutdown Effect > switch to OFF
This appears to have worked for Sleep state.
A bit confusing having 2 competing/conflicting settings for similar functions and the BIOS settings being the loser therein, but hey. I'm done.
