Results 1 to 4 of 4
    ROG Member Array
    Aug 2014
    5
    GL504GV Nahimic Audio Driver for sonic studio 3
    Hello,
    Where is the Nehimic driver? I can't find one compatible with my laptop model. On the ASUS Driver and Tools download page Nehimic is a requirement for sonic studio 3. Which I could not believe this laptop does not come with some sort of audio studio with how they advertised the speakers, which do sound decent but could definitely use an audio studio program of some sort. So if there is no Nehimic driver, which at this point is what I think is the case, is there a good substitute program?
    Thanks
    Super Moderator Array
    Jan 2013
    99
    2,169
    If you're checking the GL504GV ASUS U.S. download page for Win10, look under the 'others' section and click on the 'see all downloads' button to find the Nahimic Component Driver V1.1.8.1 .
    https://www.asus.com/us/supportonly/...Desk_Download/
    Hope this helps and if you're still using the original ASUS factory image, check under the eSupport/eDriver folder for this driver which may or may not be included.
    ROG Member Array
    Aug 2014
    5
    Hello,
    Thank you, I dont know how I missed that. I swear I looked before but must have missed it. Works perfectly now thank you again
    Jan 2013
    99
    2,169
    Glad to hear it worked out and thanks for letting us know.
Tags for this Thread
