Results 1 to 1 of 1
    New ROGer Array ahfoo's Avatar
    Jan 2020
    32
    Asus AX11000 with Asus RT-AC88U Mesh WiFi backhaul setting.
    Good day everyone. Need some advise on Asus AX11000 with Asus RT-AC88U Mesh WiFi backhaul setting.
    1. How do I determine if the the WiFi backhaul setting is enabled and how I can check on it.
    2. Do I need to enable the Smart connect for all the three band for the WiFi backhaul to enable/or to work?
