Results 1 to 2 of 2
    New ROGer Array
    Feb 2020
    1
    Question Need help from Xonar SE owners
    I wanted to ask if Xonar SE's SPDIF digital output can bring along effects such as Smart Volume Normalizer or equalizer etc?
    What I mean is if you set effects like smart volume normalizer, etc, will it be carried with SPDIF (fiber optic)?
    Appreciate the help.
    New ROGer Array quexos PC Specs
    quexos PC Specs
    MotherboardMSI B450
    ProcessorAMD Ryzen 3 2200G
    Memory (part number)2x8GB CMK16GX4M2C3000C15S
    Graphics Card #1GTX 1060 3GB
    Sound CardXonar SE
    Jul 2019
    6
    No, they will not! The SPDIF output is direct pass-through only. There are no effects, EQ, settings for it at all. Only volume. Even worse, there is a ~1-2 second delay/cutoff at the beginning of EVERY sound played, even if you seek in a video or audio file, the digital signal will instantly go dormant and repeat the delay before resuming playback, cutting off the first 1-2 second of audio again.
    A workaround for the digital audio delay/cutoff: Digital Sound Keeper v1.0.3 [2019/07/14] here: http://veg.by/en/projects/soundkeeper
    Way more details on mine here: https://rog.asus.com/forum/showthrea...lems-Any-Ideas
