Bios settings for ROG Strix X399-E Gaming
robert_sarudy
Hello,
I am kinda new to BIOS and all that stuff (former Mac user) and I am looking for an advice. I would like to apply some best settings in Bios for FAN speed vs overclocking my CPU. Currently I am running my CPU at stock settings, default settings in BIOS. My fan speeds are quite volatile, ramping up to 2200 RPM which is quite loud. Usually this happens when CPU is boosting up to 4.2 GHz. I would like to have the fans and CPU performance more constant if that is possible. I have front panel case fans 3x120 mm and radiator fans 3x120 mm on top plus exhaust back fan 150 mm
My computer specs are
CPU AMD Ryzen Threadripper 2920X 12-Core Processor 3.50 GHz
RAM 32Gb - 2x G Skill F4-3000 C16-8 GISB
GPU NVIDIA GeForce GTX 1080 Ti - Gigabyte
GPU NVIDIA GeForce GTX 1080 Ti - MSI
NVme Samsung SSD 970 PRO 512 GB
Liquid AIO with 360 mm radiator for cooling CPU.
If you can give me some kind of help or suggestions I will appreciate it a lot. THX!
0 REPLIES 0
