Results 1 to 3 of 3
    ROG Member Array
    Jan 2018
    17
    CPU System Agent Voltage always higher than I set?
    Just a quick question for you awesome people out there. I am tweaking my voltages on my i9 7960x / ROG Rampage VI Extreme motherboard to stabalise my DDR4, I have noticed that whatever I set my voltage for CPU System Agent, the reported voltage is always higher than what I set. By quite a bit. I can only think that LLC is getting involved here? Any thoughts? In this instance I had set to 1.15v.
Name:	System Agent Voltage.PNG
    ROG Member Array
    Jan 2018
    17
    Interestingly if I leave the voltage setting for CPU System Agent Voltage to Auto, the reported voltage lines up exactly with the voltage set by Auto. It seems only when I override the voltage with my own setting does it seem to be inaccurate?
    ROG Guru: White Belt Array HisEvilness PC Specs
    MotherboardASUS ROG Maximus Hero XI
    ProcessorIntel i7 8086k
    Memory (part number)32gb G.Skill TrridentZ RGB
    Graphics Card #1ASUS ROG 1080ti
    MonitorAcer Predator 27Inch/Iiyama G-Master GE2488HS-B2/ProLite E2474HDS
    Storage #1Samsung 960 EVO
    Storage #2Samsung 860 EVO x 2
    CPU CoolerCorsair 150i Pro
    CaseLian-Li Dynamic
    Power SupplyRMx 850
    Keyboard Roccat Vulcan 120 AIMO
    Mouse Roccat Kone AIMO
    Headset Sennheiser 58X
    OS Win 10 Pro 64
    Network RouterASUS RT-N18U
    HisEvilness's Avatar
    May 2017
    102
    Voltage readout is software wise always unreliable and could be different. LLC only can get involved when you can set it in the BIOS for the ringbus. And on my Hero XI i can't
Tags for this Thread
