Results 1 to 1 of 1
    New ROGer Array
    Oct 2019
    Zenith II Exterme - 10GB Ethernet Problem
    I have a recent PC build using a Zenith II Extreme motherboard.
    My router/switch has been connected to the 1Gb Ethernet connector on the motherboard which is working OK. I wanted to check the 10Gb Ethernet connector to make sure it’s working too. (I will be getting a 10Gb switch soon.)
    I took the ethernet cable out of the 1Gb port and plugged it into the 10Gb port. No sign of any problem until I opened my browser and tried to connect to a website. That’s when I got a BSOD with a message saying: “Your PC ran into a problem and needs to restart. Just collecting some error info and then we’ll restart for you.”
    It restarted and the above happened again. I moved the ethernet cable back to the 1Gb port and all is back to normal.
    As best I can tell I have the latest driver (v2.1.18.0) for the Aquantia AQC107 10Gb adapter in the Zenith II Exterme.
    Any clues and suggestions appreciated!
    Peter
