[g20aj] wifi card
guizai007
Hi all,
I am thinking to improve the reception and internet speed of my G20AJ desktop by replacing its wifi card.
Is it alright to do so and any wifi card recommendations that I can get?
A quick guide would be useful as I am a total dummy when it comes to computer hardware.
Really appreciate any advise that I can get here, thank you.
Regards,
Nick
mortenstj
SciFer3321
guizai007 wrote:
Hi all,
Regards,
Nick
Hello. I think below is what you're looking for. I just ordered it. I'll update once installed.
MPE-AX3000H WiFi 6 Wireless Card Dual Band 802.11ax Half Mini PCI-E WiFi Card PCI Express Network Adapter BT5.0 2.4GHz 574Mbps 5GHz 2.4Gbps(160MHz) for Windows 10/11 64 bit Better 7260HMW WiFi Card https://a.co/d/8Hxxob8
I purchased https://www.amazon.com/gp/product/B091FJXQHH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I believe it's the same that you're talking about; & for some reason it was strangely spotty at first & it eventually stopped working in general; I'm not sure if it's a comparability issue, a driver issue, or just a faulty car. I'm interested in hearing about your experience to narrow it down a bit.
