Armoury Crate Unable to Control ROG Ryujin (0204) Settings
Cappycot
As the title says - I have the Armoury Crate app installed on my computer and my Ryujin has the latest firmware update (0204), but I can't control any part of the Ryujin from the Armoury Crate app, except for the Aura Sync RGB lights.
I can't change the OLED (It's stuck on the default ROG eye animation.) and I can't change the fan curve for the AIO fans. I already tried updating the firmware on the Ryujin from 0106 to 0204, which is why the firmware is at said version.
Any suggestions on what I should try next?
The Vicious Cycle of the Armoury Crate:
  • Select a device to change its settings.
  • "Required to do device update to continue"
  • Check for device updates.
  • No new updates found.
  • Go back to step 1.
Rewerend
Try to unplug power cable and data cable from Ryujin with system turned off and reset bios. Then connect again and chceck if it´s working again. Good luck.
