Results 1 to 4 of 4
Thread: CPU Cores running very hot
02-20-2020 02:36 PM #1
Super Gnome PC Specs Motherboard ROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula Processor Intel® Core™ i9-9980XE / AMD 3950x Memory (part number) Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH Graphics Card #1 Asus 2080 Turbo / Asus 2080 ti Turbo Graphics Card #2 Asus 2080 Turbo / Asus 2080 ti Turbo Monitor JAPANNEXT JN-VT500UHD 4K 50-inch LCD Storage #1 Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500 Storage #2 Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2 CPU Cooler ROG Ryujin 360 / NZXT Kraken X62 Case Thermaltake View 71 TG / Thermaltake View 31 Power Supply CORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2 Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 396
My system features an Asus motherboard and Ryujin cooler. Now today, I've noticed that the CPU cores are running at 63 degrees C or so while the CPU package temperature is a healthy 36 or so degress. The utilization of the CPU is clearly at idle when this is happening--so it is not software related.
Does anyone know why this is? Is it the cooler or paste maybe?
Edit: It appears as though that while the utilization of the cores is at idle, the clock speeds are telling a different story--as they are all currently running at around 4100 MHz. Also, when I went to shut the system down, the shut down was prevented because of some security software installation underway. But shouldn't utilization (this is using HWMonitor) rise in sequence with clock speed? I am confused. And this has been going on for at least fifteen minutes now.Last edited by Super Gnome; 02-20-2020 at 02:46 PM.
02-20-2020 07:38 PM #2
idahosurge PC Specs Motherboard Rampage VI Extreme Processor 7820X @ 46 GHz / 3200 MHz Memory (part number) G.Skill F4-3600C15D-16GTZ (2 Kits 32 GB) Graphics Card #1 Zotac Amp Extreme GTX 1080 Ti Monitor Alienware AW3418DW 34" GSync Storage #1 OS - Samsung 850 Pro 513 GB Storage #2 Backup - Samsung 850 Pro 1 TB CPU Cooler Thermalright Archon IB-E x2 Case Cooler Master HAF X Power Supply Corsair AX860i Keyboard Corsair K95 RGB Platinum Mouse Logitech G703 Lightspeed OS Windows 10 Pro - 1709
- Join Date
- Nov 2017
- Reputation
- 10
- Posts
- 52
Clock speed will not necessarily change with utilization. If depends how your BIOS is setup.
For a laptop running at 4.1GHz 63C core temps are not unheard of since the cooler in a laptop is pretty small. If you have a desktop running at 4.1 GHz and you have 63C core temps at idle then that is high. If it is under a major load like a stress test or game then 63C is what I would consider normal.
02-20-2020 09:16 PM #3
EaglePC PC Specs Motherboard ASUS ROG STRIX X299-E GAMING Processor I9-7900X Memory (part number) CMW32GX4M4C3000C15 Graphics Card #1 EVGA GeForce GTX 1080 Ti FTW3 GAMING Monitor ASUS ROG Swift PG348Q Storage #1 SAMSUNG 970 PRO 512GB Storage #2 SAMSUNG 860 EVO 500GB CPU Cooler CORSAIR H115i PRO
- Join Date
- May 2014
- Reputation
- 28
- Posts
- 130
i9-7900x runs at almost 70c no OC running on a corsair h115i pro it is what to expect unless you delid
Asus Rampage VI Extreme / Intel I9-7940X / Corsair H115i Pro / CORSAIR Vengeance RGB Pro 32GB (4 x 8GB) 3000MHz / EVGA GeForce GTX 1080 Ti FTW3 ELITE GAMING BLACK Edition / 2x Samsung 970 Pro NMVe 1GB / 4x Samsung 850 PRO - 2TB / Asus ROG Swift PG348Q / Corsair AX 1500i / Thermaltake View 71 RGB PC Case /Win 10 PRO x64
02-20-2020 09:43 PM #4
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 396
Such high idle temperatures are very unusual for my system. Typically the idle tempertures are in the 28 to 32 range.
