Tuf x570 thermal paste on pcb
FuriousR9X
As the title says. I've cleaned mx4 several times with no probs. The r7 2700x Amd Tim was differenr-rubberish. So instead on sticking to cloth it bounced off in middle of 2 caps and On little transistor(metallic little square in between caps). Almost got it clean with cloth but this little transistor holds it on.
It's between 1st ram slot and cpu. How worried should I be. Is amd paste conductive? And how much holds the Asus "military grade pcb"?
Is it coated with anti conductive material?
I'll try and find some cleaning kit on Sunday but would like to know...
0 REPLIES 0
