Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
    ROG Enthusiast Array
    Jan 2018
    11
    37
    AI Suite 3.00.54 stop working on w10 1909
    Hello
    I use the "x99-e-10g ws" motherboard with the ASUS_AI_Suite_3_V3.00.54 program and it works perfectly.
    as soon as I upgrade to w10 1909 from the previous build the program cannot see the "intel mei drivers" and generates the error:
    Ensure to install MEI driver before using ASUS 5-Wey Optimization.
    I also changed the IME drivers by installing the latest release, or by reinstalling the asus original drivers. I also installed w10 1909 directly to test but error always appears.
    this problem exists only with version 1909.
    I did all the possible tests, removing, installing, changing versions, but without solution. I don't know who to write to. Asus has no direct support for these problems to write to.
    thanks
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,125
    The first thing I suggest you do is to update your BIOS to latest if it's not updated.
    Then, here are a couple previous threads with similar issue, there are a few suggestions in the threads to try, for example setting your install order and chipset driver reinstall also.
    https://rog.asus.com/forum/showthrea...y-optimization
    Davemon50
    ROG Guru: Orange Belt Array
    Dec 2017
    12
    371
    where do you see an AI Suite v3.00.54?
    Latest i could find is AI Suite 3.00.51
    ROG Guru: Yellow Belt Array Dimitrios1971 PC Specs
    Laptop (Model)GX700VO 1TB SSD + 64GB RAM
    MotherboardASUS ROG ZENITH EXTREME ALPHA
    ProcessorAMD Ryzen Threadripper 2950X
    Memory (part number)F4-4000C18Q2-64TZR (3333MHz)
    Graphics Card #1ROG Strix GeForce® GTX 1080 Ti OC-Edition
    MonitorROG Swift PG348Q Gaming
    Storage #14 x Samsung SSD NVMe 960 PRO 1TB Raid0
    Storage #24 x Samsung SSD NVMe 970 PRO 1TB Raid0
    CPU CoolerCOOLER MASTER MasterLiquid ML360 RGB TR4 Edition
    CaseROG Strix Helios
    Power SupplyASUS ROG THOR 1200P
    Keyboard ROG Strix Scope Deluxe & ROG Strix Scope TKL Deluxe
    Mouse 2 x ROG Chakram
    Headset ROG Throne Qi
    Mouse Pad ROG Balteus Qi RGB & ROG Sheath
    Headset/Speakers 1 x ROG Strix Go 2.4 & ROG Strix Wireless
    OS Win10_x64
    Network RouterFRITZ!Box 6660 Cable
    Accessory #1 BW-16D1H-U PRO
    Accessory #2 ROG STRIX ARION & Asustor AS6404T
    Accessory #3 2 x HYPER M.2 X16 GEN 4 CARD
    Dimitrios1971's Avatar
    Apr 2015
    74
    141
    Latest is the 3.00.59
    ASUS AI Suite 3 V3.00.59 Install Program for Windows 10 64-bit.
    ASUS Dual Intelligent Processors 5 V2.00.23 for Windows 10 64-bit.
    ASUS PC Cleaner V2.00.23 for Windows 10 64-bit.
    ASUS EZ Update V3.00.11 for Windows 10 64-bit.
    ASUS System Information V2.00.04 for Windows 10 64-bit.
    OLD
    NEW
    ROG Member Array lostjonny PC Specs
    lostjonny PC Specs
    MotherboardASUS ROG Crosshair Vll hero - Wi-Fi
    ProcessorAMD RYZEN 7 1800X @ 4GZ
    Memory (part number)32g G-SKILL Trident Z DDR4 3466 PC4-2700 RGB
    Graphics Card #1ASUS ROG STRIX 1080TI
    MonitorSAMSUNG UHD 55"
    Storage #1SAMSUNG EVO 250 SSD
    Storage #2SAMSUNG EVO 500 SSD
    CPU CoolerASUS LC 360 RGB
    CaseCORSAIR CRYSTAL 570X
    Power SupplyCORSAIR RM 850I
    Keyboard LOGITECH K750
    Mouse LOGITECH M570
    Headset LOGITECH G933 - ARTEMIS SPECTRUM
    Mouse Pad N/A
    Headset/Speakers KEF & Q- Audio HD - 5.1
    OS WIN 10 X64
    Accessory #1 DENON AVR X2600 H
    lostjonny's Avatar
    Sep 2017
    6
    Lost
    I can only find Version 3.00.52
    2019/08/2772.18 MBytes
    AI suite III V3.00.52
    - USB BIOS Flashback V1.03.12
    - Ez Update V3.00.11
    Im getting this error - Ai Suite 3 can't open ASio.sys !!(5)
    ROG Guru: Yellow Belt Array Rewerend PC Specs
    Rewerend PC Specs
    MotherboardAsus Crosshair V Formula - Z
    ProcessorAMD FX-9370
    Memory (part number)2 x KHX23C11T3K2/8X
    Graphics Card #1R9 Fury X 4gb Sapphire
    Sound CardAsus Xonar Phoebus
    MonitorSAMSUNG U28E590D 28" uHD + freeSync
    Storage #1Samsung SSD EVO 540 250Gb
    Storage #2Seagate 7200.14 2TB
    CPU CoolerCorsair Hydro H105
    CaseCooler Master Cosmos II
    Power SupplyENERMAX ERV1000EWT-G Revolution87+ 1000W Gold
    Keyboard Microsoft SideWinder X6
    Mouse Saitek MAD CATZ R.A.T. 7
    Headset Asus ROG Orion
    Mouse Pad Steel Series PAD
    Headset/Speakers Genius Home Theather SW 5.1
    OS MS Windows 8.1 Pro
    Network RouterAsus RT-N18U
    Accessory #1 Zalman ZM-MFC3 FAN/TEMP CONTROLLER
    Jun 2014
    12
    130
    Where we can get AI Suite V3.00.59? Is there Fan Xpert updated too? Thank you.
  7. #7
    Rewerend PC Specs
    Jun 2014
    12
    130
  8. #8
    Dec 2017
    12
    371
    I recon its designed per motherboard, so better not to install one that is not from your own motherboard support page
  9. #9
    Jan 2018
    11
    37
    Thanks I have already read and tried these links of yours but without success
    I already have the latest bios version, I have already tried all the IME versions and I have tried even if they work.
    I also installed all the w10 buid for testing.
    The problem is with the 1909 version. The basic version for my motherboard is the ASUS_AISuite3_DIP5__99-E-10G_WS_WEB_W10_64_VER30051 but I have also tried the .54 version that works perfectly with all the w10 "except the 1909"
    Quote Originally Posted by davemon50 View Post
  10. #10
    Jan 2018
    11
    37
    asus always abandons updates for its motherboards. It is a known problem.
    So you should always search independently for new versions of software and drivers free from bugs
    my motherboard works perfectly with the .51 version and with the .54 version.
    But it doesn't work with any combination for the w10 1909. "the problem is 1909"
    Quote Originally Posted by katlani View Post
