Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    ROG Enthusiast Array
    Feb 2019
    35
    R6EO and BIOS 3006 performance falling
    The BIOS of R6EO was recently updated to version 3006, but memory speeds have dropped considerably compared to version 0802, all the Settings are the same, with the exception of memory voltage, frequency, timing (18-22-22-42) and tRFC, memory second and third timing are auto, I don't know what to do now to get the same performance as the 0802 version, 3006BIOS will have an impact on 9th Gen CPU, but not on 7th Gen CPU. the BIOS 3006(the official default microcode 60), Modded microcode 49 and 69 have all been tried, with the same performance degradation, why ? is there anyone else who has the same problem as me ?
    R6EO + 9980XE 4.5G + DDR4 3800, I use Tistou77's Modded BIOS
    0802 BIOS
    3006 BIOS
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2721DE
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 980 Pro
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    128
    1,664
    You have changed the DRAM / FSB ratio ?
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 980 Pro
    SOUND: Asus Xonar Phoebus
    Feb 2019
    35
    Quote Originally Posted by tistou77 View Post
    BIOS 0802 - 3733 18-23-23-43
    BIOS 3006 - 3800 18-22-22-42
    All other Settings remain the same
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    128
    1,664
    The ram frequency has changed
    I have no difference with the 3006 (same frequency/timings) and the R6E
    Maybe tested with same frequence/timing, to see
    Case: Lian Li A77F
    CPU: i9 10980XE
    Feb 2019
    35
    I've updated them both with the same frequency and timing
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    128
    1,664
    compare secondary and tertiary timings between the 2 bios
    The changes should be there
    I use the profile, so no difference
    Case: Lian Li A77F
    CPU: i9 10980XE
  7. #7
    Feb 2019
    35
    This is the result of comparing the second and third time series of the two, and changing them to the same value as the 0802 version. The difference is still a bit too big
  8. #8
    ROG Guru: Blue Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3701 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 NEO 49 Firmware 1005.1
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 11 Insider Preview 25151.1010
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    130
    780
    Number show may look more different however in real working it was a little bit.
    Let trying CPU Z Benchmark or Anything prove that.*
    Windows 11 22H2 Build 25151.1010 Core i9 7980XE 02006D05 MCU 2021-11-13 R6E 3701 MODDED BIOS TPM 2.0 Enabled VROC 7.7.0.1054 + RST 18.31.3.5434 ME FW 11.12.92.2222 DV 2211.2.3.0 64GB DDR4 3200 XMP POSEIDON 1080i GTX NVIDIA Driver 525.14 WHQL 3TB SAMSUNG 970 EVO PLUS OMS Driver 18.37.0.1003 WHQL i219 V OROM 0.1.02 BA 0.1.16 12.19.2.45 WHQL AQC 107N FW 3.1.121 AQC 3.1.6.0 WHQL Realtek HD 6.0.9360.1 WHQL SAMSUNG ODYSSEY G9 49 NEO FW 1008 VESA HDR 2000 DP
  9. #9
    Feb 2019
    35
    Quote Originally Posted by restsugavan View Post
  10. #10
    ROG Guru: Orange Belt Array vmanuelgm's Avatar
    Sep 2013
    50
    345
    Those captures don't show secondary/tertiary timings. U can have the same primaries but looser secondaries/tertiaries and see a great decrease in performance. For example with a lower refresh interval, the Aida bandwidth is quite lower. Your captures of Cinebench and CPU-Z neither show clocks during the tests.
    U should open Asus Memtweakit and hwinfo64 apps during the tests and then take an image showing all the info ir order to have more details.
    In my case, Omega and 7980xe as CPU, 3006 provides similar results in Aida64 as 0802 using the same timings at 3800/4000, same for CPU-Z or Cinebench when clocking the CPU at 4.8GHz. Memory stability is even better in the new 3006.
    Asus x570 Dark Hero, 5950x, G.Skill 4000, 3080Ti, SM951 256
    970 PRO, 860 EVO, Intel 750, WD SN850, 840 Pro, 2xSkyhawk 4TB
    EVGA T2 1600, Silverstone TJ11, Custom LC. @Acer Predator x35
