Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    New ROGer Array
    Oct 2019
    12
    2
    ARMOURY CRATE Ryuo 240 FAN CONTROL NOT AVAILABLE (BLANK)
    hello,,
    i have do everything but in armoury crate i cant control my fans.
    it start to download the page but stops and noting is showing up and my fans are runing fast.
    other section are working but not the section were i can control the fans
    everything was runing fine till the last update.
    i cant keep reinstall windows everytime i have a problem with this **** software.
    i have buy all rog motherboard and ryuo 240 and its not working.
    Please if everyone have a fix it will be nice
    FIXED:
    You will find the fix down the page or just here.
    Close Armoury crate, go to ProgramData/Asus/armorySDK/AIO and delete aioFAN.xml
    just open armoury crate and the page is back to control the fans again for my case i have restart my pc and everything is fine now.
    ROG Member Array
    Apr 2018
    15
    I too am having the same exact issue,
    fans on AIO are obnoxiously loud,
    unable to configure the fan speeds.
    ROG is really testing my last patience!
    We as ROG customers pay a premium on your products,
    but the software support is severely lacking.
    I agree with the OP, Armoury Crate really is crap.
    ROG Enthusiast Array
    Jul 2018
    12
    31
    Same issue here on the Ryujin 360! It happened as soon as the latest update came out. Seems like a story as old as time. Update comes out breaks something.
    ROG Guru: Yellow Belt Array Rewerend PC Specs
    Rewerend PC Specs
    MotherboardAsus Crosshair V Formula - Z
    ProcessorAMD FX-9370
    Memory (part number)2 x KHX23C11T3K2/8X
    Graphics Card #1R9 Fury X 4gb Sapphire
    Sound CardAsus Xonar Phoebus
    MonitorSAMSUNG U28E590D 28" uHD + freeSync
    Storage #1Samsung SSD EVO 540 250Gb
    Storage #2Seagate 7200.14 2TB
    CPU CoolerCorsair Hydro H105
    CaseCooler Master Cosmos II
    Power SupplyENERMAX ERV1000EWT-G Revolution87+ 1000W Gold
    Keyboard Microsoft SideWinder X6
    Mouse Saitek MAD CATZ R.A.T. 7
    Headset Asus ROG Orion
    Mouse Pad Steel Series PAD
    Headset/Speakers Genius Home Theather SW 5.1
    OS MS Windows 8.1 Pro
    Network RouterAsus RT-N18U
    Accessory #1 Zalman ZM-MFC3 FAN/TEMP CONTROLLER
    Jun 2014
    12
    129
    Hello guys, heads up I found a solution how to get back control page in Ryujin, let's just go to your system drive: ProgramData/Asus/armorySDK/AIO and delete aioFAN.xml -> them go back to AC and open fan control page and BOOOM your control is back!!! Tested yesterday on my system with the lates Win updates and it works, but I am typing it from my job, so I hope i get you all info, try it if you want!
    New ROGer Array
    Oct 2019
    12
    2
    The fix
    Regarding the problem of the "fan control page", we invite you to rename or delete the file " aioFAN.xml " that you can find in the folder " programData/Asus/armorySDK/AIO " and verify if the "fan control page" works fine
    New ROGer Array
    Mar 2020
    1
    The Fix works
    Thanks for the fix. I'm a little less pissed at Asus ROG. Please add better software then Armoury Crate.
  7. #7
    Rewerend PC Specs
    Jun 2014
    12
    129
    Quote Originally Posted by mdee42 View Post
    Just one line above your post is my fix, same one looks funny this duplication
  8. #8
    New ROGer Array SkyNet79 PC Specs
    SkyNet79 PC Specs
    MotherboardASUS ROG Maximus XI Code
    Processori9-9900K
    Memory (part number)Corsair Vengeance RGB PRO 3200Mhz
    Graphics Card #1ASUS ROG GTX1080 TI OC
    MonitorBenq 32" PD3200 and LG 32GK850G
    Storage #11TB NvME Samsung 970 EVO plus
    Storage #2Sandsidk 840 PRO
    CPU CoolerASUS ROG RYUO 240
    CaseCorsair Carbide Series 678C
    Power SupplyBeQuiet Straight Power 11 850W
    Keyboard Corsair K95 Platinum
    Mouse Logitech G502
    Mouse Pad Corsair MM800
    Headset/Speakers Logitech Z623
    Accessory #1 Elgato Stream Deck
    Mar 2020
    1
    Talking Also works for ROG RYUO AIO
    Quote Originally Posted by srsbsns View Post
    Same issue on my RYUO. I have had a lot of issues with the fans hitting max and having to manually going into Armoury Crate to slow them down. Usually happens if there has been an update. I think the problem is somewhere with the motherboard - no doubt software issue.
    The above solution also for RYUO (THANKS). Please note that it is ProgramData\ASUS\ArmourySDK\AIOFan\RYUO (not program files). This folder is usually hidden folder so you might not see it your OS drive. You can unhide folder or copy paste the address above.
  9. #9
    New ROGer Array
    Mar 2020
    1
    still not working for me went in to rmoury crate, ProgramData/Asus/armorySDK/AIO and delete aioFAN.xml still the same plus i am getting missing dll 6279
  10. #10
    ROG Member Array
    Sep 2019
    It didnt work for me at first i then dele the config file in same folder then reset the armoury crete and guess what IT WORKS AND WORKS @WORKS BIG THANKU AS WE CANT KEEP REINSTALLING OS MY SET ROG CROSSHAIR HERO VII M/B ROG RTX 2070 SUPER ROG KEYBOARD CERBERUS ROG MOUSE PUGIO ROG 240 RYUJIN AMD RYZAN 3700X 32 GIG NIGHTHAWK RAM 500GIG SAMSUNG 970EV0 @SAMSUNG 870 EVO 1TB NOT NAMING ALL H/D AS I HAVE 12TB IN TOTAL ROG PSU850 DID MY BUILD MYSELF WISH I COULD GET MORE HELP WITH OVERCLOCKING BUT IT DOSE WORK SO TAKE YOUR TIME FIND THE FILES DELETE THEM @ ARMOURY CRETE WILL WORK AGAIN I THINK WE SHOULD GET PAID BY ASUS AS WE SORT THERE MESS OUT STOP DRINKING BEER AND DO YOUR WORK ASUS
Tags for this Thread
